Sourceing Studs
8 replies to this topic
#1 Old Bob
Old Bob
    TMF Menber Passed On R.I,P
  • 825 posts
Posted 24 September 2012 - 09:24 AM
I am looking for a set of four studs to fit the early top pillars of a Mk. 1 front sub-frame (two each side). They look to be 3/8th at one end and 1/4 at the other. I don't know what thread pitch they are. Anyone have a source or reference number please?
Even better, anyone got a set of four good ones to sell!
Bob
#2 Old Bob
Old Bob
  • 825 posts
Posted 24 September 2012 - 06:46 PM
Sorry to bump so soon but the post is almost off page two already! I am sure someone here will have the answer, which will be much appreciated.
Bob
#3 Barman
Barman
  • 1,068 posts
Posted 24 September 2012 - 08:03 PM
Have a look here.
Looks like 21A90 might be a replacement...?
#4 Old Bob
Old Bob
  • 825 posts
Posted 24 September 2012 - 10:42 PM
Thanks Barman. I think it's going to be a right sod trying to replace the studs with bolts - when the four original studs are fitted to the sub-frame it makes it easy to push the sub up and into the four locating holes. I fancy it will be a lot harder to drop the bolts in from above and find the threads.........
Perhaps living with a Mini was never meant to be easy!
Bob
#5 freshairmini
freshairmini
  • 1,718 posts
Posted 25 September 2012 - 11:25 AM
could you not use some threaded bar as a replacement to studs?
#6 Old Bob
Old Bob
  • 825 posts
Posted 25 September 2012 - 11:32 AM
Unfortunately not. The studs are 3/8th at the lower end and 1/4 at the top. I guess they really need cutting on a lathe but I don't have one!
Bob
#7 freshairmini
freshairmini
  • 1,718 posts
Posted 25 September 2012 - 11:34 AM
what about welding the two sizes together, or is that a little too bodged unsafe? :D
Edited by freshairmini, 25 September 2012 - 11:34 AM.
#8 Old Bob
Old Bob
  • 825 posts
Posted 25 September 2012 - 12:52 PM
Not impossible but not too sure I would trust my welding there.
Bob
#9 Udo
Udo
  • 1,670 posts
Posted 25 September 2012 - 02:11 PM
Somerford are listing them as obselite so unless you can find some second hand you will have to revert to bolts I think
