Wiring Help !
Posted 25 September 2012 - 02:47 PM
the car is an 82 998, with the starter solinoid on the wing.
here goes, the coil has 3 wires that attach 1 of which i remembered were it goes, one but have 3 wires left so i no 2 go to coil and 1 to oil pressure switch
1 wire connects to the starter solinoid
then the other 2 are part of the main loom near dizzy cap and one shorter than the other,
does any one have picture of the wiring please must be early starter motor type cheers
Posted 25 September 2012 - 02:55 PM
whats the colour codes of them i'm sure someone will know what they are if not i can look them up, i've got a wiring diagram somewhere.
Trac
Edited by tractor, 25 September 2012 - 03:01 PM.
Posted 25 September 2012 - 03:29 PM
Posted 25 September 2012 - 03:37 PM
Posted 25 September 2012 - 03:42 PM
Posted 25 September 2012 - 05:20 PM
Any more help just ask
Graham
Posted 25 September 2012 - 05:33 PM
White goes to coil positive
white/black goes to coil negative,
White/brown is oil pressure switch
purple/black is horn
green/blue is water temp sensor
If the looms original the only wires going to the solenoid
Should be
White/red from ignition to energise solenoid
Browns to battery terminal on solenoid
Brown/blue to battery terminal on solenoid
Larg cable on other threaded terminal to starter motor
Edited by lrostoke, 25 September 2012 - 05:37 PM.
Posted 25 September 2012 - 07:24 PM
Trac
Posted 26 September 2012 - 04:40 PM
Posted 28 September 2012 - 07:40 PM
Posted 28 September 2012 - 07:47 PM
I gave all the colours in my last post
Posted 28 September 2012 - 07:50 PM
Posted 28 September 2012 - 08:03 PM
