First off i have used the search function extensively and haven't found the answer i am looking for.
I am rebuilding a 1275 as a fast road to this spec:
1293 rebore.
21253 pistons.
megajolt.
HIF 44.
Stage 1 kit, changing the mini sport cone for a real K&N cone filter.
FDR (unknown right now but will be be stripping to the gearbox within the next couple of days)
Now for the questions.
1) Today stripping down the timing chain i was pleased to find someone had fitted a duplex drive. I don't know the mileage of the engine so should i replace the chain to be safe or will it be fine to leave it?
2) Getting to the cam i found that that someone had fit a kent 643. As above don't know the mileage, the cam is a little rusty and there is an amount of wear on the lobes, my question is should i keep it or change it out for something like the SW5 or even a kent 266?
3) This may seem like a very silly question but to remove a verto clutch and flywheel do i need to remove the large bolt in the center first before using a puller...
I only ask because i bought this socket from mini spares http://minispares.co...px|Back to shop
And well i can't fit it onto the nut because of the "shroud" around it is in the way.
Anyway cheers for reading
Edited by firemonkey110, 25 September 2012 - 08:52 PM.
