Posted 24 March 2006 - 01:44 PM
As Lt-SD has said, HIC quoted me £1200. That was on a classic policy so doesn't take any NCB into account, but also doesn't accumalate any either. I'll be 21 in May, with 2 years driving experience in June, the quote was based on a B16 Vtec engine, something like an 8k agreed value and limited milage to about 8k as well.
Again, as Lt-SD has said, the cheapest conversion, in terms of cost and insurance, would probably be the 1.4 K series engine (I believe Evolution on 16V MC has this conversion), but then it will be probably the least reliable out the three, and a lot of people think that if your going to go that far you may as well do the Vaux or Vtec conversion.
I think if your trying to get the best of both worlds then the Vaux conversion would be ideal, probably the 1.6 conversion rather than the 2 litre to keep expense and insurance down. Marc on here is doing this conversion with the Allspeed frame. I believe he's paid just over a grand for the whole kit and then you just need the engine/donor, which is very reasonable indeed! And theres plenty of crashed Corsas out there to use as donors.
The Vtec is the conversion I'm doing. I got the engine, loom, ECU and a couple of other bits for under £300, but B16 engines usually go for about £400-600. Again, kits for the conversion as usually about £1100-1500.
To have the conversion carried out for you I think you'd be looking about a minimum of 5-6k, and thats will a solid car to begin with. Several companies will do this, Allspeed, Watsons, SAE, P&L Minis; I recommend Watsons or Allspeed, I've heard some bad reports about P&L.
