Water Pipe Placement
plugfaebervie
, Sep 26 2012 10:27 PM
2 replies to this topic
Posted 26 September 2012 - 10:27 PM
Not 100% sure where the pipes go on my busa mini its mainly the dmsller ones but as shown in pic im not sure if this hosa requires a bung etc? Any help would be great thanks alan
Posted 07 October 2012 - 09:31 PM
Hi Alan, the fitting which appears to have a thread inside is for the coolant temp sensor if you are NOT using the original bike clocks, remember to earth the senor!! the one above goes to the header tank FEED which is at the bottom and the one off the thermostat housing goes to the top of the header tank.
If you need any more help, give us a shout.
Geoff
Geoff
Edited by drayton min man, 07 October 2012 - 09:34 PM.
Posted 12 October 2012 - 05:14 AM
Hi Geoff,
Just the answer i was needing cheers i will be using aftermarket clocks of some kind so i'll keep the grounding part in mind.
Ps nice mini
Ps nice mini
