Problems Running On Choke
Posted 27 September 2012 - 09:41 AM
Had the car set up few months back now and has run faultlessly since.
However a couple of days ago the car started running rough when on choke and the car seemed to get bogged down when I accelerated - take foot off throttle and it picked up.
Anyway today the car wouldnt even start. Well it did start but felt like it was only running 1 or 2 cylinders - couldnt get it to pick up so had to leave it on the drive.
Will have a look tonight but any ideas what to check?
I will take all plugs out and clean them and check dizzy cap and leads but I'm thinking its carb/fuel related. Car was running fine late last night when I parked it up.
Posted 27 September 2012 - 09:45 AM
Car running fine once warm?
Posted 27 September 2012 - 11:32 AM
Car runs perfect when warm.
Almost certainly its choke related I think.
Posted 27 September 2012 - 05:13 PM
Took plugs out - they were on the black side and wet with petrol. - no surprise there.
Cleaned them off and heated them up on gas stove. Turned engine over then put plugs back.
Checked dizzy cap all looked fine but gave it a clean anyway.
Also checked oil level in dash pot - fine
Tried starting and again burst into life on 2 or 3 cylinders. If I try throttle nothing. If I pull choke out engine dies.
Any ideas?
Posted 27 September 2012 - 05:50 PM
How much the choke lever comes out when you pull it and how mush does it lower the jet before opening the thottle butterfly?
Posted 27 September 2012 - 06:00 PM
Choke pulls out 30mm
Jet moves around 10mm in total
Posted 27 September 2012 - 06:48 PM
Is yours checkmate fitted with single HS4 or with twin Hs2?
Posted 27 September 2012 - 07:59 PM
Will try the adjustment tomorrow
What exactly does the choke operate - just the jet? And idle speed?
Can I clean jets out as this could be the problem if I have rubbish drawn thru
Posted 28 September 2012 - 08:36 PM
Posted 28 September 2012 - 08:42 PM
The choke mecanism lowers the jet by a lever and opens the butterfly by the bolt pushing to the throttle lever, nothing else. This provides mixture enrichment (lower jet) and fast idle speed (butterfly open).
I dont think cleaning can solve the issue, but why not try.
Have you adjusted fast idle speed as per hynes?
Posted 28 September 2012 - 09:19 PM
Ok no secondary jets or anything to worry about
How do I remove jet to clean?
I will check fast idle but guess I need it running for that?
Posted 29 September 2012 - 08:44 AM
Posted 29 September 2012 - 09:28 AM
Will let you know how I get on
Posted 29 September 2012 - 01:09 PM
You have fuel delivery, otherwise plugs wont be black and wet. But you could have a blocked/worn needle jet in the float chamber.
I'd be tempted to remove the float lit and check both the float clearance and the needle jet. Its all explained in the hynes, feel free to ask if you need further explanation.
Posted 29 September 2012 - 09:41 PM
Checked out electrics today and 4 strong sparks. Deffo thinking fuel now.
Tomorrow will check carb out and fuel delivery
Did try it again today starts and runs on 2/3 cylinders, acc pedal does nothing and choke just cuts engine out.
Will check my Haynes manual
