Cooper MPi erratic idle
Posted 24 March 2006 - 04:14 PM
The old unit was inspected and no obvious faults could be found - there were no cracks, nor was there any distortion (detectable with the naked eye). There must have been something not right though!
Suffice to say, I'm delighted with the results. The only downside was the cost - £150 all in. A bit on the steep side, but ultimately worth it in my opinion as it's made the car even more pleasurable to drive!
Any MPi owners suffering similar idling problems may therefore want to consider replacing their old plastic throttle body with an alloy version before they consider replacing expensive MAP sensors, Lambda sensors, etc.
Hope this is of use.
Cheers,
Kwack.
Posted 24 March 2006 - 04:47 PM
Mine's been a little erratic, nothing too noticable, but u know its not quite settled, if you know what I mean!!
Good mod to start saving for!!
Posted 24 March 2006 - 05:15 PM
Posted 24 March 2006 - 05:53 PM
No modifications to the ECU (or anything else) are required apart from the need to remove one of the fuel rail clamps (replaced with a cable tie) - this is due to the fact the Minispares version has a throttle butterfly which fully opens (i.e. 90 degrees) when compared to the standard plastic version which only goes to three-quarters open (about 75 degrees).
All-in-all, a very straight-forward modification!
Posted 24 March 2006 - 05:55 PM
One of the minimags did this month not sure which one.
The ecu is good for upto 90 Bhp i believe.
the way i see it, it is like fitting a 1.75 inch su instead of a 1.5 inch. Does that make sense?
Posted 24 March 2006 - 06:05 PM
Posted 24 March 2006 - 07:44 PM
yup this is right, it would overfuel, your best off leaving the size at the standard 48mm.The trade-off is that fuel consumption apparently increases significantly. There's also the slight risk that the engine will be over-fueled (i.e. very rich) which could ultimately result in damage to the cataytic converter - nasty!
Posted 24 March 2006 - 07:53 PM
Posted 24 March 2006 - 08:45 PM
Posted 24 March 2006 - 10:35 PM
i think you can fit the 52 mm throttle body as a way of upping the power on a fairly standard engine.
4BHP max
Also why would it over fuel, you are alowing more air to be drawn in, if anything it will be lean. The ecu will ad more fuel to compensate for this, but then the engine will only consume as much air as its Volumetric efficiency will alow and so the fueling will be much the same, fitting a bigger throttle body does nothing if the engine does not need the air. what it does is increase response. Also the 3 or 4 BHP extra is at the top end because the standard plastic itwm does not open fully anyway.
Posted 24 March 2006 - 11:23 PM
You may well be right about the ECU compensating. I spoke to quite a few people about this and read quite a few reports on the advantages and disadvantages and concerns about over-fuelling seemed to come up frequently, not to mention concerns over rough running and fuel consumption. Minispares quote the following regarding the 52mm version:
"FOR TWIN POINT CARS ONLY THIS BODY IS 52MM WHICH IS OVERSIZE AND FOR USE WITH OTHER TUNING MODIFICATIONS .THE ECU MAY REQUIRE MOFIFICATION FOR BEST RESULTS"
The Burlen literature makes no mention of modifications required to the ECU and goes on to claim up to 10% power increase at the top end when used in conjunction with a performance exhaust. As you say - whoopee! For out-and-out racers, I'm sure there's a gain to be had. But for old farts like me, using the car on a daily basis its likely to make little if any difference.
At the end of the day, you pay your money and you take your choice. I made my choice and I'm merely reporting that I'm happy with it.
