Gearbox Clutch Rattle
Posted 27 September 2012 - 12:54 PM
Posted 27 September 2012 - 06:05 PM
Posted 28 September 2012 - 11:05 AM
Posted 28 September 2012 - 04:47 PM
Thats a classic sign of idler gear bearing wear or out-of-spec idler gear end float.
If you tick-over is very low or slightly lumpy (hairy cam) this can make the noise worse.
Does the noise disappear if you raise the tick-over speed slightly?
If the idler gear bearings are worn or the end-float too large the idler tries to "wander" and in severe cases can ruin the clutch housing/gearbox thrust washers and casing faces etc.
Cheers, Steve.
Posted 29 September 2012 - 09:10 AM
Posted 29 September 2012 - 11:34 AM
Posted 29 September 2012 - 03:16 PM
Cheers Steve got the clutch off yesterday found 3 of the 6 bolts on the pressure plate have come out and been rattling around, hence the noise!! Damaged the 2 plates but everything else ok! New clutch ordered!!!
Oh blimey!!!!
Good job you found those.....could have been nasty!!!!
Glad you found the problem though
Cheers, Steve.
Posted 01 October 2012 - 02:47 PM
Posted 01 October 2012 - 08:22 PM
