Why Why Why
minimad82
, Sep 28 2012 07:01 PM
8 replies to this topic
Posted 28 September 2012 - 07:01 PM
fitted new engine and had forgot to lable wires on coil and oil pressure switchm,( muppet i no !!!) with help from lads on here got it wired up but the oil pressure light is really dim ( like me) any ideas??????? car is a 999 1982
Posted 28 September 2012 - 07:36 PM
Do you mean when you first turn the key before it fires up?
When running the oil pressure warning light shouldn't be on. If its coming on then it would suggest a problem with the oiling system. Check first of all that you have enough oil in it.
Posted 28 September 2012 - 07:42 PM
no before fires up
Posted 28 September 2012 - 07:43 PM
Firstly is the engine running - when light is lit ? - if Yes , get a gauge , pipe it up to the sensor hole & confirm you have oil pressure
If you have pressure at the gauge -
I would short the oil pressure sender wire to the block - is the bulb now bright ?
if yes then I suspect the sender is faulty - they can leak , and oil / carbon gets between the contacts creating resistance
so the bulb will be dull
hope this helps
hope this helps
Edited by sledgehammer, 28 September 2012 - 07:46 PM.
Posted 28 September 2012 - 07:46 PM
no not running dont dare start it. just t turn key 1 turn, and really dim
Posted 28 September 2012 - 07:49 PM
Is the battery flat? What colour wire do you have connected to the oil switch - and what colour to the coil? I suspect you have the oil wire on the coil..........
Posted 28 September 2012 - 07:52 PM
no batt all good, the wong wire could be good as im colour blind and i forgor to lable wires lol
Posted 29 September 2012 - 11:42 AM
I appreciate your difficulty. Coil negative is white/black to distributor and possibly tacho, oil pressure is white/brown, and with old, dirty, faded wires it is a mistake that anyone could make. White/red also sometimes gets confused with white/brown. Coil positive is white, no stripe, so you will be able to identify that one ok.
I suggest that you clean the ends of the wires carefully to make the colours more visible, and borrow someone with normal sight for a minute to tell you which is which.
Posted 29 September 2012 - 04:35 PM
pain but far worse off people than me, cheers for that
