Wheel Cylinder
6 replies to this topic
#1 alsy
alsy
  • 338 posts
Posted 29 September 2012 - 08:28 PM
How do I go about changing a rear wheel cylinder, not after a detailed guide just a quick run through.. Thanks
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 29 September 2012 - 08:39 PM
Strip the rear brake out completely - release the cylinder (big clip at rear - use sharp screwdriver(s)) - remove the brake pipe (if you can - best to have a new pipe to hand...) remove old cylinder/fit new cylinder and then connect the pipe to the new cylinder before too much fluid runs out - and then fit the clip, and re-assemble the brake. Free off the levers before refitting......and new shoes if oil has leaked on the old ones.
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 29 September 2012 - 08:59 PM
Job done.......do not forget to take a pick before you start the strip down just in case you forget wich way the springs go round..... :highfive:
#4 Ethel
  • 26,580 posts
Posted 29 September 2012 - 09:25 PM
Couple of tips, put some polythene sheet under the reservoir cap and/or clamp the rubber hose to reduce the fluid loss. Turn the old cylinder, rather than the pipe union, to unscrew it - less chance of twisting the pipe.
#5 jonny d
jonny d
  • 1,148 posts
Posted 30 September 2012 - 12:21 AM
now thats a good tip ive just done mine the normal way and had to renew the pipes because they twisted DOH
#6 Ethel
  • 26,580 posts
Posted 30 September 2012 - 12:37 AM
To be fair they are better off replaced if they are bad enough to seize & twist.
#7 alsy
alsy
  • 338 posts
Posted 30 September 2012 - 08:32 AM
Mercy to all!
I forgot to take a picture of the springs, I think I've got it right.. Anyone have a picture so I can be sure? Hah
