Running In ...
mjpuds
, Sep 29 2012 11:58 PM
9 replies to this topic
Posted 29 September 2012 - 11:58 PM
whats a good running in mileage for new piston rings ...on a new block.....1380 ....
Posted 30 September 2012 - 07:24 AM
The rule of thumb I use is
Running in an engine 1200 to 1500 miles
Running in brakes or new clutch 300miles
Probably a load of complete rubbish but had never let me down
Posted 30 September 2012 - 09:54 AM
http://www.mototuneu..._in_secrets.htm
that's pretty much how i've always done it. generally do about 300 road miles and always try to do it as one run.
Posted 30 September 2012 - 09:58 AM
god thats going to take me for ever.. daily driver to work and back .. adly only 4 miles . i normaly add more miles to it just for fun .. 1200 miles ..hmm looks like i need some long journeys.. at average speed of ?...
Posted 30 September 2012 - 10:00 AM
if you spend 1200 miles of gentle driving you're going to end up with some nice shiny polished bores
Posted 30 September 2012 - 10:17 AM
Agree, long runs so it gets up to temperature & plenty of throttle but keep the revs down.
Posted 30 September 2012 - 12:46 PM
i run mine in the way that the tick over half throttle and full throttle way, not saying it the right way but seems to work and be fast, but does proberly reduce engine life,but the last 1380 lasted 30k kicking just over 110 bhp
Posted 30 September 2012 - 09:41 PM
In one run, at around 30-40% of the throttle pedal depressed let the engine rev in 4th gear to 6500 and let it drop down to 2500rpm without taking gear out. Repeat 15 times. Do that with the cheapest 20-50w oil you can find. After the 15th time you are all set, change oil and filter, I suggest Motul 10-50w or Castrol 10-60w. It's very important first time you fire up the engine to let it iddle for 10-15 minutes at 2200-2500rpm, without letting it drop bellow that. Cheers,
Posted 01 October 2012 - 10:03 AM
I run mine softly in for about 400 miles going below 3500rpm
Then after that slowly built up
Posted 01 October 2012 - 10:14 AM
Just run it fairly normally with no full-on acceleration and not letting the revs drop too low when the engine is under load.
After about 200 miles it'll be run in.
With new rings and honed bores you don't want to be too gentle.
I've had a competition engine with new rings and a light hone and after a regular re-build, when I changed the cam, it was on the rolling road after only 40 road miles. That caused no problems at all despite a full power run at 6500 rpm.
