Still investigating my carburettor problem.
HS4 dismantled and cleaned.
Just a couple of queries;-
1) I used 5W-30 Castrol Magnatec in the damper - would this be ok? 20W-50 I think is usual
2) There is no adjustment on my chamber float. Its the later plastic float with a spring loaded cut off valve - is this correct? Haynes say bend the metal tab but mine has no tab
Edited by KSTANDSTEVE, 30 September 2012 - 11:31 AM.
