Steering Column & Switchgear Idea
3 replies to this topic
#1 Noris8322
Noris8322
  • Just Joined
  • 201 posts
Posted 30 September 2012 - 09:16 PM
Hi,
I'm looking into fitting an Mpi steering column and switchgear into my 1988 Designer. I know that the wiring is completely different and its gonna be a challenge to sort out.
Has anyone on here done this conversion before? Or is it even possible?
#2 sledgehammer
sledgehammer
  • 3,098 posts
Posted 30 September 2012 - 09:35 PM
I can't see why it wouldn't be possible
I would remove the airbag cartridge first - & don't refit it , as you don't want to accidentally set it off
is the steering wheel in the same position ? -
- re-align the rack to suit (loosen rack u-clamps - tighten pinch bolt & column clamp - re-tighten u clamps)
I am assuming the rack pinion splines are the same ?
& fit a new pinch bolt & nut - they often weaken , wearing the splines
#3 Noris8322
Noris8322
  • Just Joined
  • 201 posts
Posted 30 September 2012 - 09:53 PM
The air bag cartridge would be one of the first things to go in the bin. I think the possition is the same, but I'd be fitting a lowering block. The rack pinion splines should be the same, some people fit a Mpi sportspack steering rack to a standard column when they have fitted 13in wheels. A new pinch bolt is a defo, just for piece of mind
#4 Minimad_Diver
Minimad_Diver
  • 29 posts
Posted 30 September 2012 - 10:36 PM
I've done this on my '81,
Only issue I had was getting the connectors for the switchgear, but Rover 200, 400 and 800 series all shared the same switchgear as the MPi so once I knew that, it was a simple case of a trip to the local scrappy and cutting out as much of the loom as I wanted :-)
Works well, just remember to take the wiper control box (looks like a red relay), then you get the intermittent wipers as well.
