3 Cylinder Idle Problem.
5 replies to this topic
#1 CGilmour
CGilmour
  • 68 posts
Posted 30 September 2012 - 10:02 PM
Evening peeps! =]
Another Sunday passed Another mini problem.
My 1982 Mini Austin HLE running a Metro A+ 998 (Un-sure on year) SU Carb using Ducellier Ignition. Has developed a Idle running problem.
It seems to be only running on 3 cylinders on idle. When you take HT lead number 2 off it doesnt seem to drop in engine tone. As when 1, 3 and 4 are removed (individually of course) the engine tone drops dramatically.
I have ran through checks:
. Replaced all 4 spark plugs (Electrode gap set correctly)
. Swapped Plugs around incase a plug is faulty
. Replaced HT leads (also checked they are in the correct order)
. Re-set points gap correctly
. Checked for cam wear on distributor
. New distributor cap
. New rotar arm
. Done a compression test (All equal at 10 bar)
. Timing is correct and checked
. Valve gaps are correct
After all of those checks, start her up, still idles wrong. Pull off HT lead number 2 again... seems to make no difference. However when the engine is under load it seems to run fine no backfire or lumpy running.
When I remove HT lead number 2 and then put the engine under load it makes a diffrence to the running (runs lumpy as you would expect it too)
So why is it only on idle does the car seem to run on 3 cylinders but under load it seems to be fine and run on all 4?
I would of thought if it was an air leak from the inlet gasket it would affect cylinder 1 and 2 not just 2?
Very confussed! :mmkay:
I would love your help on this as I have spent all day puzzeld! :ohno:
Thanks in advance! =]
Chris.
#2 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 01 October 2012 - 06:25 AM
Oh Chrissy! Shudda rang me I was about all day yesterday!!!! Checked the manifold gasket? Also have you pulled the plug on idle to actually check its got a proper spark on idle at cylinder 2?
Strange that its just 1 and only on idle? Have you asked josh?
#3 KSTANDSTEVE
KSTANDSTEVE
  • 439 posts
Posted 01 October 2012 - 11:36 AM
Agree with comment - check for spark on suspect cylinder to elliminate this.
Just sorted a start up problem on mine by stripping down and cleaning the carb/jets. Like you I checked all electrics first but to no avail.
#4 CGilmour
CGilmour
  • 68 posts
Posted 01 October 2012 - 04:59 PM
Graham popped round as I was doing it, we are both confussed. No I havent asked Josh yet.
If it was the Manifold gasket wouldnt it affect both 1 and 2 cylinders not just 2? As 1 & 2 share an inlet as does 3 & 4...
If you pull the HT lead off 2 and hold it to a cylinder head nut it gives a good spark. I also attached the HT lead number 2 to a spare spark plug and ran the engine, the plug gave a nice heathy blue spark. Wether its a good spark under compression im not sure.
It is very confussing. Its now making me think its an air leak or a head gasket problem... Really not too sure. If you take spark plug 2 out and shine a light in the hole looking into bore 2 you can see its wet with fuel. So its getting fuel in there okay.
Its stange it only seems to affect the idle tho, not the drive under load. O_O
Yes KSANDSTEVE I allways check the electrics 1st as 9/10 it seems to be the problem haha. The fact its only affecting one cylinder doesnt lead me to think its the carb tho.
Hmmm :mmkay: Going to keep on thinking about this one, If anyone has any other ideas while I try a few more of these ideas do share! :D
Thanks again, Chris. =]
#5 JonnyBMX
JonnyBMX
  • 865 posts
Posted 01 October 2012 - 06:00 PM
yeah chris the manifold gasket are all separate for each port so the on mine 4 inlet ports with 3 exzaust ports if one of those is blowing could cause some weirdness....
as for the headgasket what makes u think that if the compression is good and at the same level across all 4 bores?
#6 CGilmour
CGilmour
  • 68 posts
Posted 18 October 2012 - 10:13 PM
I will replace the Manifold gasket soon when I fix my tappet chest oil seal leak & see if it solves the problem :) Got a gasket ready to go on!
Thats a good point, who knows! Im just not very lucky with engines at the moment it seems :(
As long as the engine keeps on going till its time for the conversion!
