Fuel Gage
2 replies to this topic
#1 Willp775
Willp775
    Starting My Mini Up
  • 1 posts
Posted 30 September 2012 - 10:40 PM
My fuel gage will only go up until half full, I have replaced the sender unit any ideas?
#2 MiniFTW
MiniFTW
  • 697 posts
Posted 30 September 2012 - 10:45 PM
If it isn't the sender unit, then is it the gauge on the dash? might be worth trying a different fuel gauge to see if that's your problem.
Edited by MiniFTW, 30 September 2012 - 10:45 PM.
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 01 October 2012 - 01:38 AM
Remove the green/black wire from the sender and with the ignition switch in the "run" position, hold the terminal of the green/black wire to an earth point in the boot (bare metal spot). Watch the gauge over a minute or so. If the gauge goes to full, the problem is in the sender. If the gauge only goes to 1/2 full again, you have a problem with the gauge or the voltage stabilizer.
Is the temperature gauge still the original electric one and is it working properly?
