Got Motor Put Back In, Now Clutch Issue
Posted 01 October 2012 - 01:20 AM
I hope I didn't put something back together wrong. That would really suck.
Posted 01 October 2012 - 06:24 AM
Posted 01 October 2012 - 11:02 AM
This is what you do:
Undo the two large nuts in the centre of the clutch cover. The inner is the overthrow nut and the outer is the lock nut. Take care not to snap the clutch arm ball off the arm when doing this. Unscrew both of these two to three full turns each.
Pull the arm as far to the right, i.e. towards the driver' side inner wing as you can and set the gap between the arm and the 7/16" AF stop bolt at 0.020". Lock the stop bolt in place.
Now check that the top of the arm has a linear minimum travel of 0.50".
Have the clutch pedal pushed as far down as it will go and hold it there. Screw the inner overthrow nut, the one with the flange on the inner end, in until it just touches the clutch cover. Release the clutch pedal and turn the overthrow nut a further 1/2-a-flat inwards. Now lock it in that exact position with the outer i.e. lock nut.
The clutch is not correctly set to manufacturer's settings.
Posted 01 October 2012 - 12:05 PM
Posted 02 October 2012 - 03:53 AM
I think i'm gonna pull the clutch cover off and see if everything is put in right. Once the adjusting nut is adjusted, there isnt enough travel left in the slave cylinder to disengage the clutch.
What should I be looking for if nothing stands out?
Edited by 74mini1000, 02 October 2012 - 03:54 AM.
Posted 08 December 2012 - 08:40 AM
Posted 08 December 2012 - 08:50 AM
You need to completely re-set the clutch.
This should be a sticky - Cooperman must be tired of typing it!
Except change 'not' to 'now' in the last sentence....
Posted 08 December 2012 - 10:30 AM
Here, again, is a full clutch fault-finder for clutch drag, which is what you have:
CLUTCH DRAG
Clutch drag or failure to disengage is not an uncommon problem with the Mini.There are several possible causes as follows:
A. HYDRAULIC SYSTEM
1. Wear in the pedal spindle or failure of the pedal to master cylinder clevis pin.
2. Failure of seals in the clutch master cylinder.
3. ‘Ballooning’ of flexible hose due to internal hose degradation or damage
4. Air in system due to inadequate bleeding
5. Failure of slave cylinder seals
B. MECHANICAL SYSTEM – WITHDRAWAL MECHANISM
1. Wear in top clevis pin
2. Wear in lower clevis pin
3. Bent arm
4. Worn or broken ball at lower end of arm where it engages into plunger.
5. Wear in plunger ball seat.
6. Incorrect setting of overthrow stop nuts
7. Incorrect setting of adjusting screw (pre-Verto)
8. Corrosion between plunger and clutch cover due to lack of lubrication.
9. Thrust bearing failure – accompanied by a lot of noise.
C. THE CLUTCH ASSEMBLY
1. Failure of clutch diaphragm spring due to fatigue or distortion
2. Centre plate hub not sliding on primary gear splines.
3. Clutch plate surface de-laminating or breaking up
4. Distorted clutch plate.
5. If fitted, clutch plate shock springs broken and causing a ‘jam’.
6. Primary gear not rotating freely on crankshaft due to either: i) Insufficient primary gear end float, ii) Primary gear bushes seizing on crankshaft, or iii) Primary gear bushes breaking up
Edited by Cooperman, 08 December 2012 - 10:31 AM.
Posted 08 December 2012 - 06:25 PM
Posted 08 December 2012 - 06:31 PM
