after the car cooled down, there was a loss of power. i originally thought it was the spark plug.
the car has a lack of power, idles well. changed the carb to another i have car ran better with slight more power but still not there. couldn't drive it. [But did not have change to tune it stop on and the Carb has be sat in the garage for a while nearly a year. ( can not guarantee the carb.)]
ok new plugs fitted.
vgood spark on all 4.
compression 150, 150, 155, 150.
no loss of water,
no loss of oil.
no smoke.
all valves adjusted as they should be. (did not need changing, but all checked.)
dizzy timing not changed (all marked up.)
I do have a veneer pulley could that have slipped?
Carb does sound like its sucking air more than it used to. on both carbs.
But I think its the carb. could the carb just break down after cooling down on the track. originial carb was rebuilt start of the year and modified to vizs guide.
You options please. thanks
Edited by booton, 01 October 2012 - 06:29 PM.
