Confused By My Dizzy
8 replies to this topic
#1 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 05 October 2012 - 08:40 PM
Getting confused by distributors...the number on my dizzy is 41907A, which according to the forum is a Lucas 59D4. But mine doesnt have the vacuum trumpet thing. Any ideas if mine is a 59D4 or if the PO took of the vacuum?
#2 jaydee
jaydee
  • 8,565 posts
Posted 05 October 2012 - 08:46 PM
Probably removed the vacuum thingy to have it with fixed advance curve. Probably has bobs and weights modded to have more max advance.
http://members.home....distributor.htm
#3 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 05 October 2012 - 08:49 PM
could i tell by removing the cap and having a look?
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 05 October 2012 - 08:52 PM
Fit a dizzy with a vacuum advance - you need it for decent economy, and to 'brighten' the engine on initial acceleration.
#5 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 05 October 2012 - 08:56 PM
is this possibally why she pulls away so crap without building the revs quite a bit?
#6 carbon
carbon
  • 2,590 posts
Posted 06 October 2012 - 06:37 PM
Is your car a 998 post-82?
The 41907A is a 59D4 fitted as standard to some of the 998s, and did not have vacuum advance.
#7 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 06 October 2012 - 07:23 PM
It's a 1999 mpi but engine swapped to a 1380 with HIF44. No idea when the engine is from.
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 07 October 2012 - 01:35 PM
Pretty much every link I could find for the dizzy mentioned gives it as for 998 A plus
Part Number is ADU 5789 and it does show as having a vac advance unit
As standard it gives a low maximum advance of about 20 degrees @ 4400 rpm
#9 carbon
carbon
  • 2,590 posts
Posted 07 October 2012 - 06:29 PM
This distributor may not be well suited to your 1380, will need quite a lot of static advance. Centrifugal advance for this dizzy is :
- 2 deg @ 1000 rpm
- 8 deg @ 2000 rpm
- 14 deg @ 3000 rpm
- 18 deg @ 4400 rpm
Above are degrees of advance at crank, and at engine rpm. This is for standard spec unit, as long as nobody has messed with springs or weights.
