Specialist Components 1340 Twin Cam
17 replies to this topic
#1 adder501
adder501
  • 33 posts
Posted 07 October 2012 - 09:25 PM
Hi,
I have just started building a 1330 Specialist Components twin cam conversion.
Follow the build and detailed updates on my blog - www.twincammini.com
The blog is a work in progress also so it will improve.
Ad
Attached File  AdobePhotoshopExpress_20120930215153.jpg   67.23K   27 downloads
Edited by adder501, 07 October 2012 - 10:05 PM.
#2 DeadBert
DeadBert
  • 86 posts
Posted 07 October 2012 - 09:51 PM
Excellent. I'm doing this conversion early next year so thanks for sharing the information! Will look forward to following your progress.
Chris
#3 oltonlad
oltonlad
  • 2,401 posts
Posted 07 October 2012 - 09:55 PM
nice conversion, but a 1275 +60 is a 1330 not 1340 ;-)
#4 adder501
adder501
  • 33 posts
Posted 07 October 2012 - 10:04 PM
Ill get that adjusted for you.
Ad
#5 wolfie
wolfie
  • 1,149 posts
Posted 07 October 2012 - 10:06 PM
Less than 500kgs i doubt that!
Work on the engine looks good.
#6 adder501
adder501
  • 33 posts
Posted 07 October 2012 - 10:13 PM
Cheers Wolfie should be 650kgs
Ad
#7 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 08 October 2012 - 05:18 AM
are you selling the drill template after your finished with it ?
freaker
#8 adder501
adder501
  • 33 posts
Posted 08 October 2012 - 11:54 AM
Hi freaker,
I don't think I will be right away as this will be used again for a 16valver. Or depending how this one goes it could be onto building another 8 valver for our other mini.
Parts have been delivered to radtec hopefully the head will be done by Friday. The block could be away slightly longer perhaps ready for collection start of next week.
Cheers Ad
#9 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 09 November 2012 - 07:29 PM
Looking good hows it going? are your pistond flat tops?
#10 Sam Walters
Sam Walters
  • 2,765 posts
Posted 09 November 2012 - 11:29 PM
Do not drill those stud holes on a piller drill or using that template. Not if you want them to be straight or anywhere near the right position.
Get it done on a mill with at least a DRO.
76mm side to side clocked off the front three stud holes and 86 front to back.
#11 adder501
adder501
  • 33 posts
Posted 15 November 2012 - 06:08 AM
Hi Sam,
Thanks for highlighting these figures. The block will be modified using a miller and clocking has been discussed with the machine shop.
The recent Lack of updates are due to travelling with work and now a holiday away. Im planning on ordering the conversion kit when I return. And start looking for a decent crank pulley.
Pistons are dished in this engine build.
Ad
#12 In-a-mini
In-a-mini
  • 831 posts
Posted 15 November 2012 - 10:07 PM
Ah ok just wondered if dished pistons would give a high enough cr with the chamber size of the 8v head.
#13 adder501
adder501
  • 33 posts
Posted 05 December 2012 - 08:43 PM
Hi "in-a-mini" sorry for a late reply.
With this project I'm following the basic design that SC used in their first 1293 twin cam engine. This was fitted into the White SC clubman estate. This engine produced around 105-110hp with a CR of around 10.4:1 using 95RON fuel. The AE slipper pistons that are being used have an 8.3cc central dish. Pockets will have to be cut into the pistons but i'm unsure of the actual cc of these so i'm leaving it for SC to do. The 8 valve head has around 23cc chamber size in standard form. With the alloy welding that has been done to the head, i will have to take some material off the face to confirm it's flat, so this 23cc will decrease slightly. The SC head gasket that will be used is 0.6mm giving 2.85cc. The block has been decked and we're using a standard stroking crank and +060" pistons.
I will be calling John at SC tomorrow just to confirm my calculations but i'm hoping of around the 10.5:1 figure.
Blog has been updated with more pictures tonight incase people want to have a look.
Ad
#14 adder501
adder501
  • 33 posts
Posted 02 February 2013 - 12:07 PM
Just an update to say the blog has been updated today. Parts have arrived!
Ad
#15 mini_nutz
mini_nutz
  • 117 posts
Posted 03 February 2013 - 11:26 AM
Good luck with your build.
Have you seen my SC K1380rs build on TMF?
Warren
