Door Shimming
Posted 08 October 2012 - 05:35 PM
Because over the last year the A panels and other components have been replaced, the doors need to be re shimmed for a better fit.
What is the best way to do this.
From playing around with washers, I have come to the conclusion that the bottom hinge need to be shimmed between the door and the frame, and the top needs to be shimmed on the inner wing.
How ever, when I try this, the door wont shut as the lock catches!
Is there an easy way of shimming, or is it trial and error?
Can I get new shims from MiniSpares?
Thanks!
Posted 08 October 2012 - 05:43 PM
You can slacken the door latch , the loop on the B pillar get some movement there to adjust the latch
Also you'll be suprised what a bit of pulling and lifting on the door will do, just don't go mad
Posted 08 October 2012 - 05:44 PM
It is basically trial and error once the door is sitting right you can move the door catch on the B pillar so the door shuts right. Adding shims on between the inner wing will not do anything.
Beaten to it
Edited by alex-95, 08 October 2012 - 05:45 PM.
Posted 09 October 2012 - 11:23 AM
Flat shims are available which fit between the hinges and door post.
In most cases adding/removing shims from the top/bottom hinges will sort out how your door sits in the frame and get the gap between the A-panel and door & the door to B post right, or at least better than it was!
Also you can move the trailing edge (rear edge) of the door up & down using hinge shims to get the door to fit better along the bottom edge.
As already mentioned above, the door striker plate can be moved up/down & in/out to make the door line up with the rear quarter panel and help with door height along the swage line (matching them up door-to-rear panel). Adjustment of the striker plate will also help get the trailing edge of the door to shut flush with the rear quarter panel.
On the leading edge of the door where it bolts to the door post, you can elongate the door post holes with a file, both up/down and in/out. Again, this will help get the front of the door the correct height and allow alignment of the door skin to the A-panel.
So there is loads of adjustment that can be made, it's just that it can be a right old faff keep taking the door off and on to check after adjustements have been made.
I always "line" the door aperture and the back edge of the A-panel with wide masking tape. This will help prevent paint/panel damage when re-fitting or removing the door several times!!!!!
The key is trial and error and plenty of patience....and if it aint going right, walk away and try again later.......it took me a whole day to get one door right on my old Mini but all the effort made it really worth while, and by the end of the exercise the door gap was as good as my modern car.....no mean feat on a Mini!!!!!!
Cheers. Steve.
Edited by Stevie W, 09 October 2012 - 11:26 AM.
Posted 09 October 2012 - 11:34 AM
Posted 24 November 2014 - 06:46 PM
Hi all, I have bought some stainless shims for my door from an Ebay supplier and modded them for an "easy fit". However when I went to fit them between the door and the hinge I found that the screws have a weird slotting arrangement (I thought they were allen screws to begin with) so my question is - what kind of tool do I need to undo these screws? I have already relocated the catch plate but I just need a little more lift to the door itself. Thanks peeps.
Posted 24 November 2014 - 07:47 PM
Can you post a pic?
Posted 24 November 2014 - 07:53 PM
Posted 24 November 2014 - 07:55 PM
I think it's better to shim between the hinge and a-post rather than the door and hinge.
But as above a torx bolt
Posted 25 November 2014 - 03:38 PM
Ah, ok - one more question; as the hinge itself disappears from sight are the bolts accessible from under the wheel arch? Thanks.
Posted 25 November 2014 - 04:27 PM
