Hilos Or Adjustarides?
Magna-Flash
, Oct 08 2012 06:15 PM
8 replies to this topic
Posted 08 October 2012 - 06:15 PM
What should I get? Pros´n cons?
Posted 08 October 2012 - 08:16 PM
I think they are the same thing. Both adjust the ride height of the car.
Posted 09 October 2012 - 01:26 AM
I'm form Aus, so I have a slightly different selection, but over here the order of quality goes as follows:
Adjusta-ride: Work fine, don't drop as far as other brands, need a different size knuckle joint.
Hilos: Shinier, go a bit lower
Ripspeed Hilos: Full height range, proper drainage and good quality.
Matt Reid (aka 'Miniman') Adjustables: Machined alloy, choice of radius for different ride stiffness, full height range and drainage. Best quality.
Posted 09 October 2012 - 06:39 AM
as far as i know hilo's are the only mini adjustable suspension that are shaped to adjust the spring rate when lowered
the rest just adjust height
Posted 09 October 2012 - 09:37 AM
How does a chunk of aluminium stuck on the end of the rubber donut adjust the spring rate? Shape or otherwise, short of piercing into the donut won't affect it's spring rate.
There's nothing stated about that on the information of them either.
Always keen to learn though.
Posted 09 October 2012 - 10:57 AM
I don't know but there could be overhanging metal, and as the doughnut compresses it metal touches it, increasing surface area and altering spring rate?
Weight dispersed over a larger area won't penetrate as far as pinpoint weight?
Posted 09 October 2012 - 12:21 PM
The problem would be the impinging element would have to be linked to the shaft of the unit, so it would project further the lower you went to provide varying increase as you wound the hi lo down, otherwise it would provide no benefit.
Posted 09 October 2012 - 02:35 PM
Hm.. OK, interesting! So HILOS from Minispares then? Just want to get the best quality and easiest to fit...
Posted 09 October 2012 - 09:50 PM
it's to do with the shape of the seat on the hilo that the rubber spring sits on
