I bought her off a friend at work as he needed some cash to emigrate to Australia...
Originally he had a 1992 mini saloon. the plan was to do a complete resto on it. but digging deeper into the shell he noticed that it would have been a big welding job.. like a lot of minis the tin worm had really set into it... so with a garage full of spares and no shell, a friend of his dads came along and offered him a bare (ex-police) van shell... upon reciept of the van it was sent to the grit blasters to get rid of any unwanted rust. what came back was a bare shell needing outer sills, doorstep panels, front panels, rear doors and main doors..
the car was then primered, painted and rebuilt and did a london to brighton a few years back...
this is how it looked when i bought it
im sure a couple of you might recognise it as i know my mate was a member of this forum...
So the plan is to get it back on the road...
step 1: Paint
after sitting in a garage and being used as a parts shelf the car adopted some fairly sizeable scratches and was begining to rust.. some migh say that the van is perfectly ok and should be given a blow over in the spray booth... but me being me. Im going to respray it..
so in to the booth she goes:
all rubbed down and ready for a coat of primer
coat of primer on and flatted back
the doors and bonnet are waiting to get the same attention but i just have'nt had the time...
Step 2: Engine
The 1275 engine that came with the van was from the 1992 saloon that my mate was going to restore... it looked filthy and oily and crusty... so i set about rebuilding it.
with everything stripped it was time to clean, machine and buy new bits... for all my machining work i am using JONSPEED in Nuneaton... they have been a great help and very informative.
here is a list of the things have had done to the engine so far:
rebore to 1310cc
SW5 camshaft
lightened and balanced flywheel
reground and balanced crank
i balanced the conrods end on end to 0.1 gram
+40 thou high compression pistons
new big end bearings
new main bearings
CNC'd combustion chambers
New bigger valve seats cut
new valve guides
double valve springs
nothing on this engine has been left untouched and everything external has been grit blasted, enameled and lacquered..
i just wish i could load more pictures!! the ones taken on my phone are too big!!
can anyone help??
for ignition i have just bought a megajolt system...
the only thing is that im a bit afraid to do the first fire up on this system as its unformiliar territory for me...
has anyone here ever done their first fire up of a new engine with this system? please let me know!!
For now anyway the engine is built. i had to order a 4 degree offset woodruf key to get my cam timing just right but apart from that its pretty much there...
next stop
the paint shop!!! cant wait!!!
