my mini sounds like a machine gun
4 replies to this topic
#1 stumpf
stumpf
  • 18 posts
  • Local Club: staffs minis
Posted 26 March 2006 - 03:59 PM
When trying to start my mini the starter sounds like a machine gun???and car don't start. Have changed the starer but it still sounds the same.
Any ideas Guys
THANKS
#2 NateDogg2909
NateDogg2909
  • 188 posts
  • Local Club: NottsAboutMinis
Posted 26 March 2006 - 04:19 PM
Bad sounds normally mean bad things (normally)
Have a gander at your plugs n leads just encase, make sure u dint knock the LT lead off the coil, silly thing to do that stops it from starting it does.
Err, starter motor connects to the engine through the flywheel housing i think, aint stripped back that far yet, but it has teeth and wotnot so make sure you've got it all snug before u try turning it over.
And the last thing is that other things turn over when u turn the key, eg, rad fan, dizzy, altenator that sorta thing.
Really i dont know mine aint done that yet, but stare at it for a while then give it a technical whack and try again, lol
Nate.
#3 stumpf
stumpf
  • 18 posts
Posted 26 March 2006 - 05:21 PM
Done it now the battery had gone flat while fitting radio, and TRYING to fix
reversing lights. next time will try easy option first.
Cheers. :rolleyes:
#4 bristolminimad
bristolminimad
  • 850 posts
  • Local Club: Swindon Mini AsoCiates
Posted 26 March 2006 - 05:39 PM
take the starter out and check the teeth on the fly wheel, could be they are warn and the starter isn't engaging properly
#5 Silicon Skum
Silicon Skum
  • 741 posts
Posted 27 March 2006 - 12:47 AM
Glad you got it fixed :rolleyes: 9 times out of 10, it's always a flat battery that gives a machine gun sound.
For future references (and others searching this site for answers), this could be a couple of things, if it a similar noise that a starter motor makes when there is not enough voltage in the battery to turn the engine ( sounds like "A-TAKA-TAKA-TAKA-TAKA....") ?
If so, this could be that :
A ) battery is flat or has a faulty cell.
B ) Faulty connection on battery terminals or faulty main cable (+ cable) / faulty earth strap.
C ) could be a faulty connection on the solenoid or failing solenoid.
There could also be some problem that is stoping the starter from turning, check that the engine can be turned over / is not seized (try a bump-start) and also worth checking that the starter is alligned correctly and bolted in place properly.
SS
