Cam Stiffness
17 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 13 October 2012 - 04:04 PM
After fitting a new oil pump and cam plate triangle, the cam seems tight and doesn't move completely freely. Is that normal at first? Fyi oil pump bolts are to correct torque 10.
#2 Cooperman
  • 23,287 posts
Posted 13 October 2012 - 04:42 PM
Did you fit new cam bearings, or a new cam? Is the head on with push rods & valve springs?
#3 tiger99
tiger99
  • 8,584 posts
Posted 13 October 2012 - 04:46 PM
No, definitely not normal. I assume the chain and valvegear are not fitted yet, and you are just spinning the shaft and pump.
It makes me suspect that the shaft is effectively too long and is under pressure from the pump at onne end and plate at the other. I seem to recall that there were certain differences between engines, and some combinations of bits would require a shim, particularly a 1275 pump in a smaller block.
What engine, pump and cam is it?
#4 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 October 2012 - 06:07 PM
Cam and bearings have not been changed.
Yep engine out, no valve gear on ( well apart from the cog, helping me turn it) just spinning by hand. Feels stiff on each cam of the pump but the pump spins freely off the engine.
1275 a+ block, sw5 cam Turbo pump, replacing turbo pump. The old triangle had quite a deep groove on it, i might see what its like with it back on.
Actually thinking about it the new triangle was ok before i put the new pump on, suppose i'll have to try the different combos to findthe problem. Should there be any max sideways movement like with the crank shaft
#5 jaydee
jaydee
  • 8,565 posts
Posted 13 October 2012 - 06:11 PM
Oil pump not engaged properly..weird because triangle plate should not fit in this case
Cam followers issue?
#6 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 October 2012 - 06:24 PM
Just put the old pump back on and turns fine. Its as if the the slot on the put is a couple on mm too much ( may be?)
#7 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 October 2012 - 06:26 PM
Follows not even touching ( block upside down at moment)
#8 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 October 2012 - 06:27 PM
Is there a gasket for the triangle?
#9 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 13 October 2012 - 06:54 PM
yep... might just make the difference you need :D
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 October 2012 - 07:08 PM
Just put the new one back on, torqued up and ok. One cam in pump got a bit of bite but moves round. Perhaps pump just needs a bit of use.
#11 mini13
mini13
  • 3,810 posts
Posted 13 October 2012 - 07:21 PM
drop the pump off and try the cam on its own, if thats ok, pull the back off the pump and check for any debris etc,
#12 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 13 October 2012 - 07:52 PM
I found on my engine that a Cam bearing had not been put in all of the way so when I torqued the oil pump up it seized the whole thing solid! Just a point for future reference:P
#13 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 October 2012 - 09:20 PM
Cam and bearings not changed
#14 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 October 2012 - 09:22 PM
You know what... I wrongly assume the inners of the new pump would not need any attention. I'll check it out in the morning.
#15 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 October 2012 - 09:24 PM
Had no gasket in the gasket set
