Lubricating The Drop/transfer Gear Roller Bearings
8 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 14 October 2012 - 08:12 AM
Putting things back together and just wondered what lubricates the roller bearings? Do i just grease them up with a bit of LM grease or does oil get through to them at all? Cheers
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 14 October 2012 - 08:17 AM
never lubed then before.
just use eng oil as they get oil in use. hence the seal higher up to protect the clutch
#3 tiger99
tiger99
  • 8,584 posts
Posted 14 October 2012 - 04:48 PM
Yes, the lowest gear in the train chucks up a lot of oil, as it is dipping in the sump oil. And, leakage from the main bearing trickles down. There is no shortage of oil in that area.
It does no harm to put some LM grease in the rollers if you feel better by doing so, because then there will be lubrication during assembly and before you start it up.
#4 03jkirk
03jkirk
  • 465 posts
Posted 14 October 2012 - 05:22 PM
dont use LM grease as it is not soluble with the engine oil u would be much better using cam lube as this will dissapate with the engine oil wen running
#5 Ethel
  • 26,580 posts
Posted 14 October 2012 - 05:38 PM
I'd use a moly based engine building lube, oil is directed at the inner bearing as it drains down.
#6 tiger99
tiger99
  • 8,584 posts
Posted 14 October 2012 - 06:23 PM
Technically correct, but a small amount of LM in an engine does no harm, and every Mini owner should have a supply of it anyway.
#7 jaydee
jaydee
  • 8,565 posts
Posted 14 October 2012 - 06:31 PM
Torqo engine lube, the pinkish stuff
Others use LM grease or even STP
#8 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 14 October 2012 - 07:20 PM
I'll put some redline assembly lube on them
#9 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 14 October 2012 - 09:11 PM
And don't forget to oil the transfer gear thrust washers.
