Window Winder Mech's Jumping
1 reply to this topic
#1 oliver122
oliver122
  • 1,007 posts
Posted 14 October 2012 - 11:46 AM
hey guys , so in the process of rebuilding my mini and ive put my glass in the mechanisms worked fine before i took them out just abit stiff , now ive put them back in , with new rubber seals all round the glass , and the mechanisms have started jumping when you try wind them up or down :S was wondering if anyone's had the problem before and how they got round it
#2 tiger99
tiger99
  • 8,584 posts
Posted 14 October 2012 - 04:24 PM
Yes, it happens on most cars eventually, because either the teeth on the drive gears wear, or the bearings wear, allowing the gears to come out of mesh. Sometimes you can fix things like that, for instance by building the quadrant gear up with weld and carefully filing new teeth.
Whatever, you need to take the mechansisms out for a look.
