how do i fit the dizzy drive, what possition does it need to be in? please give me tips.
Alex.
dizzy drive
Alex1380
, May 28 2004 07:18 PM
3 replies to this topic
Posted 28 May 2004 - 07:18 PM
Posted 28 May 2004 - 07:21 PM
if you buy a haynes book (the older light blue version), it has detailed instructions on how to do it, with pictures.
Posted 28 May 2004 - 08:50 PM
To fit the drive I use a rocker stud because it has the same thread as the thread in the end of the drive. Check the Haynes book for the positioning tho. If you were to draw a line across the groove, it should point at No.1 spark plug, but the groove is off-set and I cant remember off the top of my head which way up the off-set has to be...
Also, when you fit the shaft in, the teeth are helical cut so you'll heve to put it in about a quarter turn anti clockwise of its final position because the helical shape will twist it by about a quarter turn clock wise.
Posted 28 May 2004 - 09:01 PM
wicked thats told me what i need to know
easy job.
thanks
Alex.
easy job.
thanks
Alex.
