How To Go About Fixing This?
Noah
, Oct 14 2012 08:43 PM
5 replies to this topic
Posted 14 October 2012 - 08:43 PM
http://www.flickr.co...N03/7684924854/
Its on the B-Pillar drivers side looks like someones had the window out before with a crow bar!
Posted 14 October 2012 - 08:47 PM
You'll have to take the window out, remove the window seal locally and dress the frame back to shape with a mallet or hammer. Then a 'kiss' of good quality body filler, rub down to profile, prime then paint.
Posted 14 October 2012 - 08:48 PM
I was thinking of slide hammering the bit thats dented then knocking that centre bit back in to use a minimum amount of filler or even lead load it depending on price?
Posted 14 October 2012 - 09:31 PM
Sand down a big portion around as you'll find rust under the cracked paint, use a decent zinc primer once you have all the rust sorted
Posted 14 October 2012 - 09:43 PM
I'd take the window out (save braking it) then use a bit of soft wood and a hammer, small skim of filler and then paint.
It will be repaired when the shell is being welded
