I have recently purchased a 2003 R1 5PW R1 engine. The engine has come with basically no ancillaries just the gearbox, block and head. I have been told that the head has been ported and polished, which looks to be true, and the valve seat angles have been re-cut to 3 degrees. This apparently helps with the flow etc (The head was an ex-beale virgin Yamaha head?).
Basically my question is: What would you guys buy (new or used) to get the best possible performance out of this engine.
I have been told the regular stuff like power commander and a good air filter etc but if you could suggest the best set-up to gain the most amount of power (Exhaust back box, commander, filter make, plugs etc) I would be very grateful. I am only just entering the world of bike engined minis and only have a basic knowledge so the more specific you could be the better :)
Also is it true you can set these engines up on either carbs or injectors? If so which would you suggest? I am looking for a small degree of reliability too
Cheers Guys and look forward to the comments!
