Moving My Shell Around
17 replies to this topic
#1 Jwatts93
Jwatts93
  • 362 posts
Posted 15 October 2012 - 10:47 PM
Basically I am about to start my rebuild and am striping the car down and doing all the bodywork that is needed, however the shell need to be moved in and out of my workshop easily preferably wheels, obviously the shell will be bare, so what have people done to move their shell around ?
#2 Miniowner123
Miniowner123
  • 987 posts
Posted 16 October 2012 - 02:42 AM
dont worry, someone seems to be on the wrong forum
i've just built up a shell dolly for this job, i used some 3x3" (3mm wall) steel box section and welded up a basic frame just bigger than the main floor section, couple of cross sections in it to strengthen it and a heavy duty castor wheel on each corner, i do plan on turning it into a jig at some point by adding all the subframe mounting points so i did make it alot stronger than need be, you can prob get away bu using any scrap you can get your hands on, good luck :-)
#3 Yoda
Yoda
  • 1,958 posts
Posted 16 October 2012 - 04:22 AM
A pallet and four caster wheels.
#4 lawrie124
lawrie124
  • 1,710 posts
Posted 16 October 2012 - 05:53 AM
Try and blag a (free) bread basket trolley from your local supermarket.
Extremely tough, plastic (to avoid scratching the underside of the car) and 4 wheels.
Works for me!!
#5 Marcos Controls
Marcos Controls
    Formally known as Polish Marc
  • 105 posts
Posted 16 October 2012 - 05:58 AM
A pallet and 4 castors from any DIY place, The ones I bought were rated at 60kg each and were around a fiver each.
#6 DeadBert
DeadBert
  • 86 posts
Posted 16 October 2012 - 07:20 AM
I used a pallet and castors too. Bare shell is so light it's easy to wheel around. A trip to a DIY store and a couple minutes with a screwdriver and you have the perfect solution.
I actually used a couple of pallets on top of each other and some other bits and pieces of wood to raise the shell higher, makes working on it easier.
Chris
#7 Jwatts93
Jwatts93
  • 362 posts
Posted 16 October 2012 - 09:42 AM
Ok thanks guys sounds good thankyou
#8 R1minimagic
R1minimagic
  • 4,660 posts
Posted 16 October 2012 - 11:51 AM
Or you could use car wheel dollies which are £20 each and either sell them afterwards or put your finished car on them, makes it a doddle moving it around the garage!!
#9 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 16 October 2012 - 12:57 PM
now to build a shell movererer
nick a tesco ( or your preffered supermarket brand) trolley and cut off everything above the wheels and lower frame.
make it a bit longer and wider
sorted, and only costs you a quid :D
Edited by Deathrow, 16 October 2012 - 01:31 PM.
Quote removed.
#10 lrostoke
lrostoke
  • 6,923 posts
Posted 16 October 2012 - 01:26 PM
I'd spit roast the shell, and make a spit on wheels.
Spit makes working on bodywork so much easier, and it'll be in its own frame on wheels
#11 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 16 October 2012 - 01:32 PM
I've hidden the unhelpful posts and removed where they have been quoted.
Apologies to the topic starter.
#12 1984mini25
1984mini25
  • 8,785 posts
Posted 16 October 2012 - 03:44 PM
A pallet and 4 casters again. One thing I also used to do was wheel the shell out of the garage, tip the mini onto its side on some old tyres, side the pallet back under and back into the garage. Made welding and painting the floors and sills so much easier.
#13 Jwatts93
Jwatts93
  • 362 posts
Posted 16 October 2012 - 03:45 PM
Thankyou for doing that
#14 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 16 October 2012 - 09:08 PM
I put some small castors on my spit, works great for everything. I would say whatever you put castors on get ones with brakes on them. If you're doing any pushing, shoving or sanding on the shell you'll be chasing the damn thing all over the garage!
#15 minidave1991-89
minidave1991-89
  • 406 posts
  • Local Club: Charnwood Minis
Posted 16 October 2012 - 09:10 PM
Pallet and 4 castors, worked a treat! and very cheap
