1972 Leyland 1275 GT
Had not been registered or ran since 1977. Was originally used as a rally car but the engine was blown and replaced with an 1098 from a clubman estate. The owner never got the car to run and it sat in a garage for all this time. I have owned it for over a year and with the help of friends, it now runs quite well with a 1275 motor from a 1971 1275 GT. Below are the specs:
Engine and Trans-
1275 from a 71 1275GT, but with rod change transmission
light port and polish on the head
Aldeon Coil
Aldeon Distributor
New Plug Wires
New Dynamo
New water and Oil Pump
HS4 Carb with MiniSport Stage one kit (Intake, LCB, K&N Filter, header back exhaust)
New Clutch Master Cylinder
New Slave Cylinder
New Clutch Line
Suspension-
New Stock Cones
Adjust-a-ride
KYB Gas Adjust Shocks
Adjustable tie rods
1.5 degree negative camber lower arms.
rear camber plates (not installed yet)
Front Poly bush kit
Brakes-Stock but in good condition
Wheels-10x6in Ultralights with Falken tires, like new
Interior-Stock interior, no rips or tears in the seats. Carpet is original and needs replaced. Tach and fuel gauge do not work, but hopefully will tackle that this weekend.
Exterior-I bought the car because it doesn't have the rust that most Minis have. It was in very good shape. It has a small bit of surface just under the gutter at the seem above the windshield and a little in the gutter on the back right hand side. Neither of which is is through. It also has a decent dent in the left side fender where something sat against it for 25 years. The paint is the original color other than the boot and bonnet which are satin black.
Lights-The two upper fogs are hooked to the brights and the two lower are hooked on their own switch.
If there are any other questions please feel free to ask.
Edited by heaveninaloaf, 17 October 2012 - 07:43 PM.
