I want to lower my mini an inch or so with hi lows, I've kyb gas a just dampers at the moment can I use these or will I need lowered dampers? Thanks
Kyb Gas-A-Just's And Hi-Lows
dotnose2
, Oct 17 2012 08:04 PM
8 replies to this topic
Posted 17 October 2012 - 08:04 PM
Posted 17 October 2012 - 08:08 PM
An inch shouldn't make much difference I'd have thought.
Posted 17 October 2012 - 08:16 PM
should get away with that. only really need short ones if its slammed Jap style on the bottom stops.
Posted 17 October 2012 - 08:18 PM
Great thanks, not looking to go that low, just want to reduce the gaps between my arches and tyres
Posted 17 October 2012 - 08:46 PM
I've got gas a justs with hi lows, they're fine.
Posted 17 October 2012 - 09:26 PM
and so have I they work fine
Posted 17 October 2012 - 09:54 PM
hey, every inch counts
Posted 18 October 2012 - 08:48 AM
if your concerned lower a inch mark the dampers take off and see you still got plenty
more movement not bottoming out
inch should be ok tho
make sure your bump stops have at least 3/8 gap
Posted 18 October 2012 - 09:01 AM
Despite popular belief... "lowered shocks" only help in stopping the suspension falling apart when on full droop.
As the mounting points stay as original: they are no 'shorter' when compressed than a standard one.
So: assuming bump stops are in place, standard shocks wont 'bottom out'...
Lowered shocks have a shorter travel, so that on full droop the trumpet and rubber spring dont fall out...which is more of a problem on the rear...
