3 Clock Dash Question Mpi Spi Carb
15 replies to this topic
#1 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 18 October 2012 - 08:16 AM
hello
will a set of clocks from a later mini mpi/spi with rev counter inc fit a 1987 mini with 3 clocks or is the wiring different.
#2 minimaxie
minimaxie
  • 1,687 posts
Posted 18 October 2012 - 08:18 AM
not sure but pretty certain MPi's n SPi's use Nippon Seiki type gauges whereas the older Minis use Smiths?
#3 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 18 October 2012 - 09:09 AM
i was told the wiring is different, as per comment above.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 October 2012 - 09:21 AM
Dimensionally they will fit, not sure if the connector fits, but one thing to be aware of is the tacho on the later mpi clocks runs off the ECU not from a coil feed, so it will need recalibrating
#5 charie t
charie t
  • 3,153 posts
Posted 18 October 2012 - 09:35 AM
Connectors fit the same, the rev counter can be re calibrated by turning the screw on the inside.
#6 jaydee
jaydee
  • 8,565 posts
Posted 18 October 2012 - 10:19 AM
The SPI will work, while the MPI not and will read twice. As guessworks said mpi rev counter can be recalibrated to be used with standard coil.
#7 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 18 October 2012 - 10:22 AM
yet again guys thanks a lot. this is a great forum id be lost with out it.
always some one who knows what i dont.
#8 charie t
charie t
  • 3,153 posts
Posted 18 October 2012 - 06:11 PM
And why will the mpi not?
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 October 2012 - 06:15 PM
Because the mpi runs a wasted spark ignition system
#10 charie t
charie t
  • 3,153 posts
Posted 18 October 2012 - 07:12 PM
yah, but its very easy to adjust it, so is just as useable. There is no need to send it away
#11 79 clubby
79 clubby
  • 165 posts
  • Local Club: .
Posted 18 October 2012 - 07:38 PM
i have the mpi 3 dial speedo in my 79 clubman and it works fine.
#12 tiagotiks
tiagotiks
  • 10 posts
Posted 13 August 2016 - 12:54 PM
Does anyone knows if it necessary to use a different coil? Mine is a lamentation.
Regards
#13 tiagotiks
tiagotiks
  • 10 posts
Posted 06 November 2016 - 11:50 AM
Hi guess works. Where is that screw located in the tacho to calibrate it? This can be done by someone or has to go to a specialist?
#14 tiagotiks
tiagotiks
  • 10 posts
Posted 06 November 2016 - 01:09 PM
#15 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 06 November 2016 - 08:43 PM
There is a variable resistor on the rev counter that can be used to adjust the reading. This can be done by yourself with a timing light
