Clutch Problems...
Posted 21 October 2012 - 07:23 PM
thanks steven
Posted 22 October 2012 - 11:13 AM
Posted 22 October 2012 - 05:16 PM
Edited by steven, 22 October 2012 - 05:17 PM.
Posted 26 October 2012 - 08:40 PM
Posted 26 October 2012 - 10:00 PM
Posted 27 October 2012 - 08:31 AM
Apart from a broken, chewed or otherwise mutilated plunger, there are at least two possible causes, firstly the throwout stop is, as already suggested, not set correctly (check and adjust first), and secondly (Verto only), the slave cylinder is running out of travel when the piston hits the circlip. (Not all have the circlip, but I would not advise removing it.) It does that because an accumulation of wear in the lever ball end, plunger, thrust bearing, pivit pins etc, all give additional free play, which the self-adjust spring in the slave cylinder compensates for by moving the piston outwards, so it then does not have enough travel remaining to do the job. Some people have bodged this by fitting a longer push rod to the slave cylinder, generally by welding on an extension, but that is a dreadful bodge and should not be necessary. (OK to get the car working in the short term, but a proper fix should be found.) It may be that in these cases, the main problem is that the lever has bent, and a new one may cure the problem.
I would take apart and check all the external parts first, which is no big deal unless your car is an awkward one with a brake servo or other bits in the way. Check the lever end for wear (flats on the ball), and the pivot for slop (pin should be a good fit in the clutch cover and the lever). Same with the pin between lever and slave push rod. Lubricate with something like graphite grease and reassemble if everything is good.
But before doing any of that, get a torch, and become a contortionist for a few moments. Check that nothing is jamming the pedal or master cylinder push rod.
To set the throwout stop, first set the return stop clearance to 0.5mm (non Verto only). Loosen the throwout stop nut and locknut considerably. Check that pedal will now go to floor and get someone to hold it there. Tighten stop nut till it contacts clutch cover and then one flat more. Tighten locknut against it.
Posted 27 October 2012 - 05:01 PM
i have checked the throw out stop witch seems okay
it was bodged before i got it there was a socket attached to the push rod inside the slave cylinder
im also going to start taking all the external parts off tomorrow checking/greasing along the way anything to look out for ?
thanks steven
Posted 27 October 2012 - 05:25 PM
Posted 27 October 2012 - 05:49 PM
is this a common problem/bodge ?
Posted 27 October 2012 - 11:07 PM
Unless, of course, the dimensions of some replacement parts such as the thrust bearing are incorrect, which would not be entirely surprising, giving the abysmal quality control practised by certain suppliers.
If anyone has other sensible ideas about why we are seeing this problem now, I for one would be very interested.
Posted 28 October 2012 - 01:59 PM
mine does not seem to be obviously bent but im going to renew it i dont think it would take alot to make it not work
thanks for the help i will keep you updated
Posted 03 December 2012 - 09:23 PM
