Engine Out
7 replies to this topic
#1 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 23 October 2012 - 09:57 AM
can a 998cc mini engine be taken out through the top with the brake servo in place??????
#2 Beej123
Beej123
  • 1,184 posts
  • Local Club: Splinters Mini Club
Posted 23 October 2012 - 10:02 AM
You have to split the master off the vacuum unit with the 2 bolts that are there and bend it (carefully) out of the way and then yes, you can. It's easier if you remove the oil filter housing and dizzy but that isn't essential.
#3 86mayfair
86mayfair
  • 557 posts
Posted 23 October 2012 - 10:05 AM
I removed the alternator, dizzy, oil filter, coil and starter motor. It's just easiest if yuo take off as much as you can to avoid damaging them
#4 Beej123
Beej123
  • 1,184 posts
Posted 23 October 2012 - 10:10 AM
Apologies, we remove the alternator and coil too. I personally see very little benefit from removing the starter motor.
If you are using an engine crane then what I've said is fine but if you are lifting out by hand then remove as much as you possibly can.
As far as ease, we probably remove and refit 2-3 engines per week so you learn how much time you can save by leaving stuff on and as long as you are careful and watch the engine as you lift, it is loads easier.
(Don't forget the speedo cable!)
#5 jaydee
jaydee
  • 8,565 posts
Posted 23 October 2012 - 10:34 AM
I have to say that you'll find it less tricky removing the big vacuum servo, removing its just 2 mins, you'll same time imho.
#6 86mayfair
86mayfair
  • 557 posts
Posted 23 October 2012 - 10:44 AM
Yeah to be honest I'm sure the starter motor would have been fine but I tend to go down the belt and braces route with everything :-)
#7 Beej123
Beej123
  • 1,184 posts
Posted 23 October 2012 - 11:00 AM
It depends on how each person prefers to do it, I have never found the vacuum bit to be in the way at all. The answer to your question is yes, you can take the engine out without fully removing the servo. The remove everything method is fine if you are only doing it once.
#8 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 23 October 2012 - 11:06 AM
thanks again guys
