Few Issues.....
6 replies to this topic
#1 i gotta mini prob
i gotta mini prob
    Just On Tickover
  • 6 posts
Posted 23 October 2012 - 05:06 PM
Back brakes failed on mot. Managed to change passenger side spreader and tighten that up.
But the other side rounded off even after lubing it up and leaving for a week.
So new back plate baught, went to take hub off and got stuck.
Got the front bearing out but the back one is being stubborn.
Didnt want to force it as didnt know if theres a trick?
Also is there any way of knowing if your headlights are correct allignment other than taking it to garage?!?
#2 Cooperman
  • 23,513 posts
Posted 23 October 2012 - 05:18 PM
Adjusters normally free off if you strip the brakes off and heat up the adjuster with a butane torch and turn the adjuster with mole grips. Then you just fit a new adjuster.
Check the headlights by shining them on the garage door.
#3 i gotta mini prob
i gotta mini prob
    Just On Tickover
  • 6 posts
Posted 23 October 2012 - 05:32 PM
Thanks uncs,
any tips on how to get 2nd bearing off.. was gonna try leavering from behind hub but didnt want to force it.
Dont have butane torch...
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 23 October 2012 - 05:54 PM
A butane torch isn't expensive: http://www.ebay.co.u...=item1c228b7dd8 plus a can of gas. If you plan to work on a mini then it will pay for itself many times over.
#5 i gotta mini prob
i gotta mini prob
    Just On Tickover
  • 6 posts
Posted 23 October 2012 - 06:01 PM
Ahhh. Thought ment like a big blowtorch. Thanks
#6 i gotta mini prob
i gotta mini prob
    Just On Tickover
  • 6 posts
Posted 23 October 2012 - 06:41 PM
... also just a quick one. Is this an injection?
#7 i gotta mini prob
i gotta mini prob
    Just On Tickover
  • 6 posts
Posted 23 October 2012 - 06:44 PM
