I need to fully remove the pedal assembly bracket off the car to drill out and replace all 4 studs. Just at the dash rail end it has those shear bolts with no heads that haven't been touched for the best part of 20 years. It's been a while since I last had to play with those under the dash rail and had forgotten how I'd gone about it before. Also does the steering column have to come out as well?
Best Way To Remove Pedal Assembly
1984mini25
, Oct 23 2012 09:56 PM
3 replies to this topic
Posted 23 October 2012 - 09:56 PM
Posted 23 October 2012 - 10:00 PM
I tried slitting with a 1mm grinding disk. it refused to budge this way so i had to just drill the centre of the bolt head out.
Posted 23 October 2012 - 10:04 PM
As above, grind the head off, drill it out or slot it
You have to take the column out and also one of the security bolts holding the bracket to the lower dash rail needs extracting
Remove the clutch split pin (easier said than done) and it should come out once the bolts are removed
Posted 23 October 2012 - 10:10 PM
It's kinda what I was expecting, just didn't fancy lying on my back with a drill up under the dash. Still I suppose I should expect it after already having to use a hacksaw to remove the clutch master cylinder. Still at least I was spared the clutch pin ball ache, as who ever bodged fitting the new master cylinder, never refitted the pin after.
Edited by 1984mini25, 23 October 2012 - 10:12 PM.
