hi im fitting a set of hs2's to my dads mini and got them all on and everything and now have realised that there isnt a vacuum advance take off on the carbs? i really need to run the vacuum for the sake of good running but how am i going to do it? been told that the take off really needs to be behind the throttle butterfly so where do i go from here?? any help would be appreciated and if its in the wrong section then im sorry but i couldnt start a topic in the relevent section! many thanks
Hs2 Carbs With No Vacuum Take Off!
minispark
, Oct 24 2012 10:11 PM
5 replies to this topic
Posted 24 October 2012 - 10:11 PM
Posted 24 October 2012 - 10:32 PM
I can't remember if the vac is before or after the butterfly.
If its after, just plum it to the manifold (drill a small hole, sink a small tube into it with fibreglass resin on the outside, sink it in and let it set. Did it on a vac gauge fitting years ago).
If its before, you could either snatch it off the big feed line for the crank case vent.
Both can be done with a drill and some thinkin', maybe a tea or two.
Posted 24 October 2012 - 11:15 PM
After, between butterfly and manifold
Posted 25 October 2012 - 04:52 PM
see if i can put it after its not a prob at all and after looking in all the crap carbs ive got its always before the butterfly??? i could just drill a hole and job done but want to know if it will work??
Posted 25 October 2012 - 06:04 PM
With dizzy ignition, you need to run the vacuum behind the butterfly, but only just. The idea, is that as soon at the throttle is operated just above idle the port is vented to the inlet manifold vacuum.
AC
AC
Posted 27 October 2012 - 05:12 PM
yea ive decided im gonna drill one into it!
