Cutting Bump Stops Down
Posted 25 October 2012 - 08:36 AM
They are about and inch and half tall, was thinking cut them in half and see how it goes as i want to get a better wheel gap than I already have.
Posted 25 October 2012 - 08:47 AM
Posted 25 October 2012 - 08:54 AM
Posted 25 October 2012 - 09:05 AM
I discovered recently my mini had very little bump stop clearance on one side, so I just raised it up a couple of turns on the hilo. It raised it up about 10mm from where it was but the car drives so much better now. No more bangs over bumps and you can chuck it into corners more.
You want to have a minimum of 10mm between the bumpstop and top arm.
Edited by mike., 25 October 2012 - 09:06 AM.
Posted 25 October 2012 - 09:17 AM
Edited by new_zealand _minis, 25 October 2012 - 09:18 AM.
Posted 25 October 2012 - 09:19 AM
Posted 25 October 2012 - 09:49 AM
If you want it to look lower, lower the arches, or buy some that are closer to the wheels relative to the body (if you see what I mean?)
Posted 25 October 2012 - 09:55 AM
I don't agree with the idea of making a car 'look low' it's either low or it's not. I wouldn't be caught dead in a car with a chin spoiler and side skirts to make it look lower than it is.
Posted 25 October 2012 - 09:57 AM
what about the tricks that Miglias use to get low?
Posted 25 October 2012 - 10:13 AM
I've just stated above that I'm getting the shorted polybush bump stops.
Posted 25 October 2012 - 10:23 AM
Posted 25 October 2012 - 10:27 AM
Now on my hillclimber I don't run bumpstops and the car is low. But even with yellow dot doughnuts the suspension was not very stiff. I had to add and ARB.
On a road car it makes no sense to go this low, you just end up with a softer front end and terminal oversteer.
As you say, your car is either low or it's not. But if you're not interested in the low look, rather the handling, then it's better to be not so low. If all you want is the look then keep it as it is and fit the smaller bumpstops.
As it happens, I was not suggesting fitting a daft kit. But there are some normal arches out there that by their design fit closer to the wheels, mig arches for example, or group 5s.
Posted 25 October 2012 - 10:28 AM
Maybe she's sitting low for a mini. But not as low as I would like
Tat does look a bit too low for any sensible use. Raising it 10mm will make little differance to the look and work better.
Posted 25 October 2012 - 10:42 AM
The wheel arch option is out because of my skinny wheel/ tyres on the front although it may get some standard ones added. I don't want poke like you see on pretty much every other mini on the road.
Posted 25 October 2012 - 10:59 AM
Edited by 1984mini25, 25 October 2012 - 11:01 AM.
