How Do I Convert To Blade Fuses?
8 replies to this topic
#1 jackgreen91
jackgreen91
  • 205 posts
Posted 28 October 2012 - 10:34 AM
I've got a 94 spi with inline fuses which are all a bit nasty inside (corroded etc.) and nothing really works electrically other than the ignition and wiper motors. I figured since it looks like spaghetti junction in there I may as well replace them all with a neat blade fuse box instead of cleaning all the terminals. How do I go about changing them over?
Cheers, Jack
#2 Barman
Barman
  • 1,068 posts
Posted 28 October 2012 - 10:44 AM
Have a look here.
But I remember on another thread about fuses somebody saying that the ratings are different (or they blow differently) - so you can't simply replace a 35A glass with a 35A blade for instance.
Worth a search...
#3 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,020 posts
Posted 28 October 2012 - 11:16 AM
Yeah I recall that too. One type is designed to run at X amps and the other type are designed to blow at X amps.
#4 Barman
Barman
  • 1,068 posts
Posted 28 October 2012 - 11:34 AM
Here...
#5 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 28 October 2012 - 11:44 AM
Amps are amps regardless of what type of fuse they run through surely.
#6 Barman
Barman
  • 1,068 posts
Posted 28 October 2012 - 11:49 AM
See the thread in reply #4
#7 freshairmini
freshairmini
  • 1,718 posts
Posted 28 October 2012 - 01:07 PM
to be honest there's no point. Replace the corroded and broken parts with new inline fuse holders and glass fuses and it'll work perfectly.
Plus it will be the correct ratings which you can't easily get with blades as there aren't direct replacements.
The glass fuses work fine and will last long enough once replaced.
#8 Barman
Barman
  • 1,068 posts
Posted 28 October 2012 - 01:21 PM
Agreed!
New fuse box and set of fuses for about thirty quid...
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 28 October 2012 - 02:42 PM
It's not the Amps, it is the way the fuses are rated.
+1 for Barman's comments. PLEASE read the linked thread in post #4. While Amps are Amps, fuse ratings are not all handled the same.
The following will NOT apply to most of you but I will mention this as an example. Lucas wiring has a terrible reputation in the U.S. BMC/BL cars that made it over here would typically have problems where fuses would blow. Owners would go to the local parts store and buy what they thought were equivalent fuses based solely on the Amp rating of the fuses. The ratings were NOT the same between the glass fuses in the U.S. and those meeting British standards. This frequently resulted in a lot of cars having partially melted or completely destroyed wiring looms. Again, while Amps are Amps, fuses are not all rated the same way. Please read the thread linked in post #4.
All that being said, when I use blade fuses in circuits, I use a multiplier of 0.6 to convert from the British Standard to blade type fuse rating.
