Heating Wont Work In My Austin Mini
8 replies to this topic
#1 jason1987
jason1987
    Just On Tickover
  • 6 posts
Posted 28 October 2012 - 11:38 AM
hello all its me again ive aquired a new problem my mini heating isnt working you turn it on it blows warm for about 30 secs then goes back cold should i remove the thermostat so its constantly flowing is the water
#2 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 28 October 2012 - 11:43 AM
The problem is, is that the heater matrix inside of your heater will be blocked up, happened to me.
What you need to do is get a bucket and a hose, remove both pipes and the matrix from the heater and then blow it through with a hose.
It'll then work like new :-)
Or if there is any problems with the matrix just buy a new one :-)
#3 jason1987
jason1987
    Just On Tickover
  • 6 posts
Posted 28 October 2012 - 12:01 PM
ok thanks i will give that a try was freezing yesterday even with 3 layers on
#4 Ryang556
Ryang556
  • 2,747 posts
Posted 28 October 2012 - 12:04 PM
I know the feeling mate!
The heaters in mini's aren't actually too bad at all when they're working properly! :-)
#5 Pelvisgt
Pelvisgt
  • 483 posts
Posted 28 October 2012 - 12:05 PM
I have this issue too, so it could be the hose the connects to the heater from the water system ?
#6 Ryang556
Ryang556
  • 2,747 posts
Posted 28 October 2012 - 12:06 PM
It will be the heater matrix itself that is blocked up, disconnect the hoses from it, put it over a bucket and blow it through with a hose :-)
#7 jason1987
jason1987
    Just On Tickover
  • 6 posts
Posted 28 October 2012 - 12:11 PM
any ideas on what a 198o austin morris mini is worth 12 months mot 6 months tax wanting to get another as a project and do it up to be on road again like this one
#8 zinzan
zinzan
  • 373 posts
  • Local Club: me and my imaginary friend
Posted 28 October 2012 - 12:53 PM
No heat in mine last year. Pulled the matrix and it was solid inside...no hope of clearing it out. Bought a new matrix for cheap off of ebay and works great now. The rest of the car...not so much!
#9 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 October 2012 - 04:24 PM
Check thermostat isnt stuck open
- Possibly replace with 88c one while your at it.
Check coolant level is good. Good time to check anti freeze while your at it.
Make sure heater tap is open and pipes to heater getting warm
If still poor, check for blockages, partially block radiator if your engine runs cool anyway etc
