Help Dizzy Wiring!
7 replies to this topic
#1 holmesy
holmesy
  • 879 posts
Posted 29 October 2012 - 09:20 AM
right I've put the mg metro engine into my 1989 mini thirty and now I'm confused about the wiring for the electronic metro dizzy. what wires go where and what should I do with the old wires that connected to the old dizzy.
any help is much appreciated
#2 tractor
tractor
  • 662 posts
Posted 29 October 2012 - 09:35 AM
i think there should only be one wire connected to your dizzy and thats a white one with a black tracer that connects to the negitive side of the coil,
or do you have electronic ignition or somthing?
Trac
sorry just read your post properly, yeah red to the plus and black (i think) to the negitive
Edited by tractor, 29 October 2012 - 09:53 AM.
#3 mayhem13
mayhem13
  • 96 posts
Posted 29 October 2012 - 09:44 AM
You can still use the old wire if you want or just tape it to the loom and use the two wires from the dizzy strait to the coil. The red one gose on the plus side of the coil if I remember and then the other on the other side.
#4 holmesy
holmesy
  • 879 posts
Posted 29 October 2012 - 09:51 AM
I have coming out of the dizzy a white/yellow and a white/black
#5 Yoda
Yoda
  • 1,958 posts
Posted 29 October 2012 - 10:18 AM
Beat me to it :proud: I could not have said it better. Make sure also that you are using the coil from the metro or any sutable 12volt coil, NOT the one from the original engine which is 9 volt and will burn out pretty quick.
#6 holmesy
holmesy
  • 879 posts
Posted 29 October 2012 - 11:51 AM
I have a Lucas gold, but also gave a top of the range flame thrower coil if that would be better.
so white and yellow goes to positive on coil and white and black goes to white and black wire hanging from the loom? and I need to run a 12v feed from fuse box to the positive as well
#7 Yoda
Yoda
  • 1,958 posts
Posted 29 October 2012 - 12:02 PM
No.
Listen very carefully.
remove existing white/yellow. positive wires from the coil and tape them back out of the way. put a new wire in from an ignition controlled live from the fuse box instead, then the two wires from the metro dizzy connect to the coil plus and minus. use the flame thrower coil for good results
#8 holmesy
holmesy
  • 879 posts
Posted 29 October 2012 - 08:50 PM
no I mean the white/yellow comes out of the dizzy module
