Megajolt Connection Pins
maccers
, Oct 30 2012 03:05 PM
3 replies to this topic
Posted 30 October 2012 - 03:05 PM
As per picture below, is there any crimp tool or less fiddly way to connect bare wires to the these pins? The yellow one is an example from something I had in the garage, the smaller one are the ones for my plug.
plug.jpg 25.58K
9 downloads
Posted 30 October 2012 - 03:13 PM
Yep, you need an uninsulated crip tool. They look like Molex pins to me.
Check a certain famous internet auction site....
Posted 30 October 2012 - 05:43 PM
The loose one looks like a molex pin. When i did mine i loosely crimped them with some pliars and put a small bit of solder on it. Works a treat as long as you dont add too much solder, as it's tight putting them in the plug its self.
Dan.
Dan.
Edited by danbmini, 30 October 2012 - 05:43 PM.
Posted 30 October 2012 - 07:26 PM
I done a test solder on a spare connector and it bent it with the heat of the iron! I think mine is not a low heat one!!
Managed to do them, only 5 of them by gently crimping with pliers.
Thanks for advice.
Thanks for advice.
