Help With Cylinder Head
4 replies to this topic
#1 fergy26
fergy26
  • 64 posts
Posted 30 October 2012 - 05:52 PM
Attached File  SAM_0070.JPG   60.11K   2 downloads
Attached File  SAM_0071.JPG   48.97K   2 downloads
Hi im currently building a 1293 engine but the cylinder head which is a 12G840, seems to have to water outlet blocked off. Does any one know why and what to do about it?
Does anyone know what the hole in the second picture is for?
#2 rally1380
rally1380
  • 1,893 posts
Posted 30 October 2012 - 06:10 PM
The water outlet is blocked because its a later typre head that took the water from the thermostat housing area instead with the use of a sandwich plate and an in line plastic water tap.
If you want the use the original water outlet then just drill it out making sure to get all the swarf (metal bits) out.
As for second hole...not sure, but i've got the same on a head of mine and it has a rivet put in it....been like that since i've had it so probably redundant on a mini and not needed.
oh and your head is probably a 12G '9' 40 head....probably a bad casting number.
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 October 2012 - 06:23 PM
Mine also has a rivet in it. I thought it was a bodge when I first noticed it, but have a seen a few now and they all have it. I can only assume it was a factory fitted bodge.
#4 rally1380
rally1380
  • 1,893 posts
Posted 30 October 2012 - 06:26 PM
Ha ha ha....factory fitted bodge.....love it!!!!! :D :D :D :D :gimme:
The hole is probably a by-product of the manufacturing process. And a rivet is probably the best (and cheapest....this is BL remember) solution as a filler.
#5 fergy26
fergy26
  • 64 posts
Posted 30 October 2012 - 06:34 PM
Great help, thanks very much
