Posted 02 November 2012 - 08:05 AM
Others will no doubt add more but from what I've heard I'd aim to do the conversion using the CG13DE.
Here's why:
The NATS immobilizer seems to be a pain in the a$$, even the Micra guys seem to find it a pain and they aren't chopping out half the loom (unless they are trying to get rid of it).
The CGA3 doesn't make that much more power than the CG13DE.
I believe the gearbox is larger, so it will be harder to get in, I think Flying Banannas conversion may have used this gearbox (or something similar) and along with using the standard inlet manifold it meant a fair bit of firewall modifications.
As you're an engineering type I guess the subframe should be a bit easier I'm at this stage at the moment and I'm hoping things will move a bit quicker once I have the subframe finalized...
The Micra conversion is pretty good in that the rest stays pretty standard mini, almost all the changes are in the engine bay and it doesn't have to chop any of the wings or firewall if you use a modified inlet manifold something like Rid's
Anyway some more threads to check out:
http://www.theminiforum.co.uk/forums/topic/193323-l-jonez-micra-build/ (Bike carbs, nice frame)
http://www.theminiforum.co.uk/forums/topic/231743-dutch-micra-engined-mini/ (a bit different subframe nice too, which may make it easy to drop the engine out the bottom?, bike carbs, front mounted alternator)
http://www.theminiforum.co.uk/forums/topic/176236-another-micra-mini/ (roll your own inlet manifold, EFI, another nice frame)
http://www.irishminis.ie/forum/viewtopic.php?f=6&t=3452&start=0&view=print (an interesting plate style subframe, probably using the gearbox the CGA3 uses I think...but I've been wrong about gearboxes before)
http://www.theminiforum.co.uk/forums/topic/161530-micramini-my-first-conversion/ (uses the standard inlet manifold, tube subframe design)
Not sure how compatible the CGA3 and the CG13 gearboxes are maybe a CG13DE will go on easy enough, or a CG10DE pre-facelift as these are smaller still, but gear ratios will probably be less than ideal.
Anyway enough to be going on with?
