Lighting Fault
6 replies to this topic
#1 TommyWolstey
TommyWolstey
  • 31 posts
Posted 06 November 2012 - 05:52 PM
Hi guys so I rebuilt my mini and came to turn my head lights on and just the side lights come on. Any ideas with what's the problem ?
#2 Craig89
Craig89
  • 600 posts
Posted 06 November 2012 - 06:19 PM
Could be absolutely anything, check to see if you have got voltage at the lamps, if you haven't then work your way back I.e. fuses, switch etc
#3 TommyWolstey
TommyWolstey
  • 31 posts
Posted 06 November 2012 - 09:45 PM
When I turn side lights on its fine, when I switch to head lights stays on sides, fuse maybe ?
#4 BenCoul
BenCoul
  • 317 posts
Posted 06 November 2012 - 10:00 PM
They both use the same fuse I believe, try checking the acctually switch?
#5 TommyWolstey
TommyWolstey
  • 31 posts
Posted 06 November 2012 - 10:28 PM
In the dashboard you mean ? Full beam also works so ur could be the switch I suppose
#6 TommyWolstey
TommyWolstey
  • 31 posts
Posted 06 November 2012 - 10:45 PM
What fuse is the one I'm looking for ? It's wirth a check and I don't have a manual
#7 son's mini
son's mini
    Just On Tickover
  • 5 posts
Posted 14 January 2013 - 07:39 PM
I am currently having a similar problem. I have got side lights and main beam but no headlights!
So far I have replaced the fuses for lights, dash board switch! And fitted brand new wires for the headlight! Yet still the problem occurs! This only leaves the relay left, is a relay problem likely to affect this situation?
