Temperature Gauge Reading Just Above Cold
9 replies to this topic
#1 Paulryanmini
Paulryanmini
  • 51 posts
Posted 07 November 2012 - 08:48 AM
Hi all
I decided to change my 2 clock dash for a 3 clock dash.
Since changing it the temperature gauge just sits above the blue mark.
I put the old clocks back in and the temperature needle sits in the correct place.
So that has narrowed the fault down to the new clocks.
PCB tracks look fine no breaks, from searching on here it may be the voltage regulator?
Mini is a spi 96
Clocks from 97 mpi (magnolia dials)
Fuel gauge works fine no issues.
Thanks in advance
#2 Mighty made
Mighty made
  • 153 posts
Posted 07 November 2012 - 11:11 AM
Try swapping the temp gauge from the old one to the new, as it might be the gauge.
I think that, behind the faces they are both Nippon Seiki, and are the same.
#3 Paulryanmini
Paulryanmini
  • 51 posts
Posted 07 November 2012 - 11:28 AM
thanks, i was just about to try that but if i ground the water temperature sender wire (green/blue) the needle goes into the red which i think means the gauge is working. :D
#4 Ethel
  • 25,951 posts
Posted 07 November 2012 - 12:36 PM
It is working, and will show if the engine gets hotter than normal. If you want it to read cold, normal, hot more accurately you could try swapping the gauge innards, or a different temperature sender.
#5 Joseph-C
Joseph-C
  • 383 posts
Posted 07 November 2012 - 01:07 PM
It probably is the voltage regulator, I have the same problem I've tried a new thermostat and sender, and when grounded the temp goes to red so the gauges are fine.
Next step:
http://www.theminifo...tage-regulator/
If the original clocks are reading right then it's nothing to worry about as the car is getting up to running temp.
#6 Paulryanmini
Paulryanmini
  • 51 posts
Posted 07 November 2012 - 01:13 PM
Next step:
I was thinking that mod might work . I'll take a trip into maplins and give it a go! Cheers
#7 Joseph-C
Joseph-C
  • 383 posts
Posted 07 November 2012 - 01:15 PM
Let us know if it does, I've got the bits but I'm being lazy and haven't done it yet :lol:
#8 Paulryanmini
Paulryanmini
  • 51 posts
Posted 07 November 2012 - 02:13 PM
i know the feeling im thinking the same. a new smiths gauge for the dash would be much nicer,now just to convince "the boss" :shy:
#9 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 07 November 2012 - 02:58 PM
I thought Spi and Mpi clocks were different?
#10 Paulryanmini
Paulryanmini
  • 51 posts
Posted 07 November 2012 - 07:44 PM
I'm not sure but they both appear the same in appearance and have the same circuit pattern I think.
