Are Sills The Only Cavities I Need To Inject With Waxoyl
8 replies to this topic
#1 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 09 November 2012 - 08:02 PM
Are the sills the only cavities that I need to inject with waxoyl or are there other areas that would benefit from this treatment. (I'm using waxoyl in a generic sense, I'll probably be using Dinitrol)?
Also where do you inject, I assume you need to drill holes and plug them after? And lastly in an older car do you need to kil and or convert the rust prior to injecting the waxoyl?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 09 November 2012 - 08:12 PM
No there is the forward bulkhead cross member, the floor cross member, the scuttle close outs and the rear valance close outs.
If there is existing rust all you will do is delay it but it will eventually come through.
#3 mike.
mike.
  • 6,176 posts
Posted 09 November 2012 - 08:14 PM
Sills you can inject through the vents or through the seatbelt holes with an extension probe.
Other box sections are the rear valance closer panels, scuttle corners which can be accessed at the top of the bulkhead near the bonnet hinges, and also the door posts which you can do through the hole where the check strap goes.
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 09 November 2012 - 09:00 PM
Also worth doing the rear subframe, in between/ below where the trumpet sits as this can collect water.
#5 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 11 November 2012 - 05:50 PM
Thanks for the replies.
In the past I've just waxoyled with a gun annually and that always seemed to work well. I guess get it up on ramps and axle stands, pressure wash any dirt, when dry spray with a rust killer, then waxoyl every thing. Would anyone advise trying to wash and treat the inside of the sills before the waxoyl?
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 11 November 2012 - 06:01 PM
I wouldn't add water to the sills unless you can make sure it's completely dry in there after, like a heated garage or something
#7 jonny d
jonny d
  • 1,148 posts
Posted 11 November 2012 - 08:19 PM
no dont wash we did it once to a mini and thought that the waxoil would chase out the water but it didnt take to the surface very well and really rusted
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 18 November 2012 - 12:16 AM
Look up Shell Ensis its used on oil rigs in the north sea, I have used it for years and IMO is better than waxoyl
#9 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 18 November 2012 - 10:13 AM
Not really a cavity, but the door bottoms benefit from wax
