Rover Mini Types?
Posted 10 November 2012 - 09:52 PM
So the Rover Mini Coopers look in my price range. But they seem to come in 3 different types. Carb, SPI and MPI. Which one is the quicker? I heard that carbs have more long term tuning options and I'm interested in trying to get the most out of the A series.
Posted 10 November 2012 - 10:00 PM
Good luck.
Posted 10 November 2012 - 10:01 PM
Posted 10 November 2012 - 10:06 PM
Carb cooper, 90-92 is one to go for or if injection pre MPI...
Posted 10 November 2012 - 10:07 PM
There are a few about on this forum... Check the rebuild threads for a blue mpi with webers and amegajolt system.
In terms of the injection cars. I own an mpi, and the generic mini companies do a good "stage 3"kit for around £1250 which will boast 90bhp...
I wouldn't push a standard gearbox and well used block much further than 90bhp... that's plenty in my book! Minispeed in Guildford do a good stage 3kit and install
Posted 10 November 2012 - 10:50 PM
Guest_minidizzy_*
Posted 11 November 2012 - 01:13 AM
There is not much difference in the performance of the different versions of the Rover Cooper and all can be tuned for better performance but the MPi's ECU will limit the engine to 90bhp.
I have a 1990 Cooper RSP S (John Cooper conversion) with twin carbs and giving 78 bhp and a 1997 standard Cooper MPi giving 63 bhp. Both seem to average 40 mpg. The Cooper S is definitely way outside your budget and carb Coopers are hard to find. I am not sure I understand the point in converting injection to carb if you are on a limited budget. If you convert to carb you also need to be careful that you can pass emission tests for the age of the engine. My S is special but I love my MPi. It drives beautifully and is very reliable.
Posted 11 November 2012 - 12:03 PM
Posted 11 November 2012 - 05:45 PM
Can an MPIs ECU be modified or replaced to allow more horsepower?
Posted 11 November 2012 - 05:48 PM
Posted 11 November 2012 - 07:40 PM
What would be the cheapest way to get 90hp? A carb one or an MPI with one of those stage 3 kits?
It won't quite get you 90BHP, but probably the cheapest way to get reasonable power in a classic mini, is to transplant in an early MG metro engine (1982-1988). Along with a correctly jetted HIF44 carb, high flow air filter, decent inlet and gas flowed exhaust system you should get 80+ bhp. MG metro units aren't as common as they once were though, so expect to pay £350+ if you find one and you'll also need £250 or so, for the carb, exhaust, inlet etc.
As far as I'm aware they cannot be remapped, although as standard they can actually cope with performance mods up to around 90 Bhp. You can fit a replacement aftermarket ECU instead that will allow you to modify to your hearts content, but from what I understand this is not a cheap option.
Posted 11 November 2012 - 08:55 PM
Posted 12 November 2012 - 07:51 AM
Posted 12 November 2012 - 08:18 AM
Mpis are the best though
At rusting yes.... they're pretty much unrivalled at it in fact!!!
Posted 12 November 2012 - 10:22 AM
