Morris 850 Semi-Resto
13 replies to this topic
#1 jor2daje
jor2daje
    Just On Tickover
  • 7 posts
Posted 10 November 2012 - 10:20 PM
Hey guys I decided to start this post as its getting closer to my winter break from college, and hopefully I can come a little closer to wrapping this project up then, hopefully starting a thread will keep me pushing to finish because I don’t know if I could go another 5 months without my mini hahah :D . I got the car this summer, it’s a 1963 Australian made morris 850, not sure if it’s a cooper or not but it has the badge haha.
I describe this project in quite boring details so feel free to ignore the text and look at the mediocre iphone pictures. I’ve never actually restored a car properly, Ive done a couple motorcycles and fixed up my mx-5 but this is by no means a professional job, I really should do a complete shell restoration but it seems to be in such great shape and I cant wait to drive it so this will do for now.
My mini project started out with the hunt, here in California finding a mini that is cheap, older than ’68 (import laws), and registered is a pretty tall order. Luckily I had seen one on the side of the road for several years in my neighborhood. So after a couple months of trying to find something online or in local papers I finally just left a note on this guys car, here’s how it stood back in 2006 on google street view and it was in the exact same place when I went to see it this summer.
About a week after leaving the note I got a call from the owner who said he would willing to sell, he was pretty confident it started and wanted $3k for it as long as I promised to restore it which was perfect for me because that was far cheaper than any I had seen for sale before. I went down but the car wouldn’t start, it cranked and I could here the pump but wouldn’t fire, so I offered him $1500 which he accepted. Luckily after seeing this
I realized it most likely just needed a new set of points so I grabbed a set from moss motors which happens to be local for me and drove the car off his driveway the same day. Here’s how the car stood when I first got it and after cleaning the 6 years of grime off, it became pretty obvious that the respray was pretty low quality and there was no point in trying to save any of the paint so I decided I would have to take it back to bare metal. The original colour according to the VIN was slate grey which can still be seen on the dash and under the carpets; this is what I plan to respray in.
The passenger and back seats were taken up with these boxes of parts which have been very helpful in keeping the cost down as I am on a student’s budget.
I then moved the mini to little space between my shed and house so I could get to work on it.
I started with the engine as I wanted to get it running right before I went any further so I removed and cleaned the internals of the carb, and figured out that the started problem was that the jet had varnished to the carb so pulling the choke did nothing but increase the throttle slightly. After fixing that it started up and ran quite nicely (having never heard a mini in person I can only assume this is running nicely haha). I put a new dizzy cap, leads, and a coil on then threw some of the completely wrong kind of paint on haha, this will be changed as soon as I pull the engine.
Then I wanted to add the tach and temp gauge that came in my box of spares, but I didn’t want to alter the iconic single gauge. So at work I wired them up so that a few simple connectors could be pulled and the cluster could be removed or installed in a couple minutes.
Here’s a video of it hooked up and starting you can hear my fuel pump which Im pretty sure is on its last legs.
http://s715.beta.pho...3ED7AF.mp4.html
With the engine running nicely I moved onto the brakes, all but one cylinder had seized but luckily they were some replacements in my box of spares. With driving pretty much taken care of I moved to the interior.
The interior was pretty nasty, the door cards look like they used to be red but were painted over, the dash liner was red but beyond help, and whatever was on the floor, some sort of vinyl material was too disgusting and torn to do anything with so it is all coming out eventually. I plan on a gray carpet I got from minispares, the black seats that were in it (no idea if they are original or not) and black door cards and dash lining. The original whitish headliner will stay for now.
After removing the seats there was really only one logical way to move the car around.
Then I started on the body work, it is in really nice shape and definitely makes me appreciate the climate in California after seeing the rust many of you have to put up with. The only areas of rot are the seams, and in the skin of the trunk because the rear window seal allowed rain water to build up there. To strip the paint I used a mix of coarse wire wheels on my angle grinder, and aircraft brand stripper which I found out the hard way will even melt some of the cheaper rubber gloves. I used an etching primer as I went because I didn’t want any rust forming between the days I was able to work on the car.
Here you can see the worst of the rust repaired, I had to cut out two pieces on either side of the left hinge and weld some new metal in, then fill and sand.
The industrial stripper is pretty awesome stuff, you can see just how thick the paint was.
Here are the only parts Ive had to order so far, and apart from an interior light and the fairly elusive/expensive morris horn push, I think this should see me through to completion.
I also have few fun bits that I couldn’t help but get/make like stamping the key on a machine at work
And getting a nice keyfob
And finally I couldn’t bring myself to put the California plates back on a holder that is so obviously not made for them so a sketchy german company on ebay stamped my number onto some euro plates. Im sure its quite illegal but hopefully if I put my registration on these the cop will understand.
I do have a couple questions some of you experts may be able to answer. First of what would have been the stock mirror style and placement? I have two sets of these fairly nice wing mirrors so I will most likely keep them but it would still be interesting to know what the original would have been. And also would this have come with seat belts? Again I will probably keep the ones that came with car but they have the British leyland logo on them which I believe this mini predates.
Thanks for looking
#2 ReggieBoy
ReggieBoy
  • 113 posts
  • Local Club: Southern Mini Owners Club
Posted 07 December 2012 - 06:53 PM
How are there no more replies to this?! I want! Nice start to the mini, looks good :)
#3 Tatty84
Tatty84
    Formally known as Sweaty Raphiel
  • 27 posts
Posted 07 December 2012 - 08:54 PM
When the car was built seatbelts were not mandatory and I belive they were an optional extra. I also have a 63 morris mini and have fitted britax lap and diagonal static belts in the front which look good in a car of that age, look similar to the belts on an aeroplane. I think the wing mirrors were an option as well, the ones you currently have fitted to the wings look about right for what would have been fitted to the car.
#4 jor2daje
jor2daje
    Just On Tickover
  • 7 posts
Posted 07 December 2012 - 11:44 PM
thanks guys, the belts on this sound similar to what you describe and thanks for the info on the mirrors.
#5 steven
steven
  • 1,195 posts
Posted 16 January 2013 - 08:51 PM
any updates ?
#6 jor2daje
jor2daje
    Just On Tickover
  • 7 posts
Posted 09 March 2013 - 02:56 AM
Hey guys quick update, I had spring break off and got a fair bit done. Managed to paint it, get most of the new weather sealing in, and put rear windshield and quarters in then finished up the soundproofing on the inside.
heres a vid of me checking that the engine was still running fine after sitting for a couple months.
#7 steven
steven
  • 1,195 posts
Posted 09 March 2013 - 10:25 AM
the colour looks great !
#8 minimikej
minimikej
  • 349 posts
Posted 09 March 2013 - 02:00 PM
Nice!
#9 Maverick78
Maverick78
  • 186 posts
Posted 09 March 2013 - 07:15 PM
Fab job! Lovely wee car.
#10 jor2daje
jor2daje
    Just On Tickover
  • 7 posts
Posted 15 March 2013 - 10:18 PM
heres how I had to leave her when I went back to school, everything but the inside doors, sliding windows, some trim and carpet is done.
#11 jamesmpi
jamesmpi
  • 1,940 posts
Posted 16 March 2013 - 11:58 AM
She looks fab. Good work.
#12 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 16 March 2013 - 12:56 PM
that does look awsome! personally i would have left the paint original and faded for the look but now you have done it she looks great!!
you going to keep the 850 engine? they are good for just pottering about little british towns that you cant really get over 50 in.. :D a 998 or 1275 engine would really make it go better!
#13 w.murfitt
w.murfitt
  • 242 posts
  • Local Club: Flintshire Mini Owners Club
Posted 16 March 2013 - 05:27 PM
Looking good, just a heads up, from the first batch of photos the number plate is on upside down....
other than that looks like a great build
#14 jor2daje
jor2daje
    Just On Tickover
  • 7 posts
Posted 16 March 2013 - 08:17 PM
thanks guys
artful dodger, I am a bit worried about the 850 haha, I dont really mind as long as I could get up to 65 but that's probably pushing it so I may need a new engine haha. Also the paint wasnt original it was some nasty thick house paint I think, the colour I painted it is a much closer match to original which was left under the carpet.
Wmurfit, youre right haha I just put it on there too check it was the same size so nothing is screwed or glued down.
